Don't go in the water
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Nov 2, 2019.
  1. lexidium
    lexidium Active Member
    235
    109
    manchester
    After the bar stewards stole my cat converter, I obviously had a new 02 sensor as well. I stripped the wires and joined them to the existing ones in a plastic junction box.
    So I'm travelling along the country lanes when in a dip there's a water leak and a small lake across the road.
    It's about 6" deep and I would have to go miles back to find another way, so I drive through it.
    Almost immediately, I get the code for 02 sensor. I've tried erasing it but it doesn't go away. So now I don't know whether to buy a new one or wait a while to see if it clears up.
    So don't go in the water, there may be sharks!
  2. Leadfoot J. McCoalroller
    7,135
    6,682
    Pennsylvania
    2018 Prius c
    The junction box likely flooded and has retained enough water to keep the error code for a while. It will probably dry out on its own though you might speed things along by opening it up and getting some warm dry air in there.
