DON'T LAUGH - please -
Discussion in 'Prius v Accessories and Modifications' started by Bambibones, Feb 28, 2019.
  1. Bambibones
    Bambibones New Member
    2014 Prius v wagon
    Can I reverse the rear seats in my 2014 V?
    I'm camperizing my Prius and reversing the rear seats for lounging legroom etc might be better than just removing them to remove The Hump.
    I already know about not removing or reversing the front passenger seat. This is about the back seats. I don't think the air bags are the same.
    The rails for the 60 side and 40 side are both 17" edge-to-edge.
    I NEVER use the back seat.
  2. Onlooker
    Onlooker Junior Member
    22
    Nova Scotia
    2014 Prius v wagon
    Technology
    new here... Why not remove front passenger seat?(Anything catastrophic? or just the airbag sensor stuff). Planning on removing back seats also.
    Did you try reversing seat?
    49,500
    welcome!
    i would search for threads on the front seats
  4. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Interesting question.
    I gather you mean switching so the seat backs now touch the front seat backs.
    1) I believe the rear seats fold flat and recline on a v, but this is uncomfortable/ not desired for your uses.
    2) Rear seats are easy enough to remove with no electrical connectors.
    3) You may be the "ginny pig" in trying and I suppose you are asking if the seat bolt bolts remain in alignment once reversed.
    4) Anything can be done with fabrication. Special seat rails for example.
    5) Only issue that comes to mind is the fan under the pass rear seat so make sure it still breathes.
    Anyway, those are my thoughts, good luck in project.
    Take photos let us know what you find.
