Don't put the jump box or cables in the storage under the hatch
Discussion in 'Gen 2 Prius Main Forum' started by ToyotaGal, Jun 12, 2021.
  1. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    Hi All,
    I have never had a warning light or any indication my batteries were going. Today, I went to the car and no lights, beeps, or sign of life. I got the newer key to make sure the mater key battery wasn't dead no such luck.
    My cables and jump box are in the hatch storage compartment. I can't open the hatch to get there. Too bad because I have a new marine battery that could have jumped the Prius nicely.
    Waiting for AAA
    Linda
    Valiant V likes this.
  2. Mendel Leisk
    38,243
    There’s a metal key that unlock drivers door, or no? It’s awkward, but you should be able to flip down rear seat back, then release hatch with emergency lever, just below hatch mechanism on the inside.
    Chodronish, mmmodem, fuzzy1 and 2 others like this.
  3. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    AAA came jumped the car. I drove it for 10mins then remember about the secret display. it said battery was at 14.4 v. Took it to O'reilly's and had the battery tested. He could not get it to register from the terminals in front so we went directly to the battery. He came back with bad. Iforgot I had a obdc scanner so I hooked that up and it said battery was at 14.2. Should I still change the battery?
  4. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Sounds like you are getting the voltage readings with the car in Ready Mode. A 12v auxiliary battery, at best should be reading 12.x volts not 14.
    Samuel Williams Jr and Valiant V like this.
  5. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    ok off to autozone for a testing
  6. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Unless your battery has a good reason to be dead - like the car left idle for weeks or the like - probably safer to replace it.
    Seems like it's not unusual for the 12V battery to only last 5 years - sometimes less.
    When O'Reilly tested it and it came back "bad" - I wonder what criteria they used and if they know that Batteries in the Prius aren't like other cars.
    With the 14.2 on your OBDII scanner, you may have been reading a charging voltage, not a battery voltage. Unless there's a different battery chemistry I'm not familiar with, a fully-charged 12V battery comes in at about 12.6v. 13.8-14.7 range is more like a charging voltage.
    [email protected] likes this.
  7. Samuel Williams Jr
    246
    Dayton NV
    You really should just go ahead and replace the volt battery now. Otherwise you will turn your Prii, into a rolling Slot Machine, sometimes it will start, sometimes it won't? Sometimes the fob will work sometime it won't? Weird stuff will go on and until the 12 finally dies and you replace it. Or you can wait until your better half get's tired of your sill crap and takes the car to a Hybrid Shop and they replace it, my bad. :(
  8. fuzzy1
    10,044
    How old is this 12V battery?
  9. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    I think it may be original.
    Autozone said it was charged but their reader was saying to replace battery. They told me to drive it a little more on the highway and let it charge. Im going to CT tomorrow and get it tested but it looks like I'm getting a new battery.
    And I'm making sure I have the jump box all charged up. I might also bring the boat battery with me!!!
    Samuel Williams Jr likes this.
  10. PriusCamper
    PriusCamper Senior Member
    10,918
    4,426
    Pacific Northwest, USA
    That jump box should work fine till you get a replacement battery... Here's the battery I reccomend, I've had one just like it in my car for almost 10 years without issue. Also enclosed below is photos of hardware you'll need to connect the terminals: https://ebay.us/vN4JsP
  11. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    update. I drive 1hour 10 mintutes to CT this am. then back. Stopped off at same place as yesterday and had the battery checked. we could not get a read from the front so we went to the battery. It came back as good. However this is an optima battery with a date of 4/16 so it is 5 years old.
  12. xliderider
    7,848
    3,102
    Honolulu, HI
    Original batteries last 5 to six years on average. If you don't drive very often and let the car sit for a while between, the lifespan will be on the shorter end.
    If you have a jump pack, you can use the original battery since it tested good. If the car sits, investing in a battery charger/maintainer would be a good idea.
  13. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    I drive the car every day. I put about 22k on it in the year since I bought it. I'm going to bring it to the mechanic tomorrow and have him test the battery.
  14. bisco
    48,974
    no reading at the jump point is prolematic
    Mendel Leisk and ToyotaGal like this.
  15. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    Operator error. Remember these are min wage kids. That's why I'm going to the mechanic tomorrow morning
    Valiant V and bisco like this.
  16. BurkPhoto@aol.com
    56
    High Point, North Carolina
    We’ve owned nine hybrids in my extended family. Nearly always, the situation you describe ends with a brand new battery.
    Auto stores typically do not understand hybrid 12-volt systems. They often install batteries meant for the wrong application!
    A new, fully charged battery will measure around 12.6 volts at the terminals (car OFF). In READY mode, the battery is charging at 13.4 to 14.x volts.
    Techs who don’t test the battery under full load (car OFF; all Accessories ON), may get false readings. A battery can “read” charged, but be unable to produce sufficient energy under load!
    I have had the least trouble with the OEM (Yuasa) replacements. Treated properly, they last at least five years.
    — Bill Burkholder
  17. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    Update,
    I went to a mechanic that uses Toyota parts. The battery was tested and replaced with a oem. Last night I used the remote to lock the car. It locked but the remote did not do anything after multiple hits. This am at 6:00 am car is dead again. Nothing was left open or on. I jumped it no issues and the battery is holding a charge.
    Does this mean the alternator is toast?
    Linda
  18. Mendel Leisk
    38,243
    Those two statements are at loggerheads? Something’s may be rapidly drawing down the battery charge.
    There is no alternator.
  19. ToyotaGal
    ToyotaGal Member
    180
    82
    Millis, ma
    I knew that
    Priusjames and Mendel Leisk like this.
  20. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    The battery this person recommends does not have one safety feature that Automotive battery's have, an external vent. Use this type of battery at your own risk.
