Don't Shoot the Messenger -- Tufoil
Discussion in 'Gen 3 Prius Fuel Economy' started by JSchnee, Mar 17, 2014.
  1. JSchnee
    JSchnee Junior Member
    Hi Everyone,
    At the risk of flaming out, I thought I'd share my humble, non-scientific experiences with using Tufoil, the PTFE/Moly oil additive in my 2012 Prius-III w/8800 miles.
    I live in NJ and my commute 53 miles each way is cold (20-40F) and hilly. I've only had the car since Jan, bought it used, and was getting 39-41 mpg in Jan and Feb according to the miles/gallons methodology.
    I've been trying a variety of things to improve the fuel economy of my mostly highway commute (15inch wheels, check; inflate to 40+ check, limit speed, check, limit heat, check, pulse and glide where possible, check). These helped some (bringing me up from 38-39 to almost 41mpg).
    Then, I made the following three changes -- unfortunately not one at a time:
    1) ran two full tanks of Techron
    2) changed from Exxon to Citgo
    3) added 8oz of Tufoil
    Now I'm getting 47-48mpg! Granted the weather has been warming up on the occasional day or two. But for my drive to work this morning, it was 28 degrees, I drove 53miles, and averaged 43mpg with an average of 70mph. Typically I would average 38-39mpg for this leg (home is more down hill).
    I have no affiliation with the makers of Tufoil and only heard about it about a month ago.
    Give it a try, what could it hurt.
    YMMV,
    Jonathan
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Well actually it CAN hurt.
    Other products containing PTFE have been found in the past to "separate" and cause a sludge problem over long periods of use. Many of those products are no longer on the market because of that.
    You can get moly already IN energy conserving oils. I suspect that most 0W20 types have it already.
    To complete your test, you need to NOT add it at your next oil change, see what the mileage is and then add it later again.
    Personally I NEVER put any extra additives in my oil......and nothing but Techron in my gas.
  3. Mike500
    Mike500 Senior Member
    2,593
    766
    I used it in the 1970's and 1980's in my Camaro with the 5.0 liter small block. The car went for over 300,000 miles and was still running fine, when I traded it in because of suspension issues.
    I now use Liqui Moly, which is less expensive.
    I get a lot of opinions from others, but at the very least, it won't hurt.
    It's coating might help in rare incidences of low oil pressure at startup, especially on a start-stop engine.
    51,154
    i'm in! love to see my 70mpg go up to 80!(y) i will report back after following o/p's instructions. this could be the miracle the world has been waiting for.
  5. Mike500
    2,593
    766
    I heard of a lot of negatives about Teflon or polytetraflourethylene buy a lot of good about Liqui-Moly, as it is widely used and recommended by BMW, Mercedes, Audi and others in Germany.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Just show me the page in the owners manual that recommends oil additives and I am in!
    [crickets chirping]
  7. JSchnee
    Like I said, your mileage may vary.
    I'm aware of the negative press and lawsuits associated with other PTFE containing additives regarding ppt, sludge, and the clogging of small oil passages. If you're more comfortable with using Moly only, suit yourself.
    I sincerely doubt Tufoil is the 3rd reincarnation of the Messiah, but from the glowing reviews it got on both Amazon and various car related boards, it seemed like it was worth a try. I plan to do the same (Techron and Tufoil) in my wife's 2007 Subaru Outbact which has ~110K.
    I did search this board and found no reference to Tufoil, so I thought it would be worth bringing up.
    I should have also mentioned, I have not yet had my recall done, and I only use 87 octane (after trying 91/93 and seeing even lower mpg).
    Here are the links for Amazon if you're interested:
    snip (unable to post -- just search for Tufoil on Amazon)
    Read the reviews, they're pretty stellar for whatever that's worth.
    -Jonathan
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Well at least you admit it's not scientific.
    As you admit you've got a couple of factors all happening at once.
    And you are only admitting to a 2-3 mpg improvement. That's too minimal for me to attribute to any one factor. The greatest of which simply might be the warming up of the weather.
    People are free to do whatever they want to their vehicles.
    When I was young I regularly added one of those "infomercial" Miracle oil additives to one of my trucks. I never put enough miles on the vehicle to know whether it helped or hurt or did anything. At this point in my life? I'm not easily sold anything. I think just using the recommended synthetic oil will be protective and efficient enough.
    I'm kind of with the "Old Fogey" thinking that if any single additive could make a huge impact on MPG, then all major oil manufacturers and automobile manufacturers would start recommending it and using it and adding it.
    Since this is not the case? I feel no compulsion to go out and buy some and pour it in my engine.
  9. Mike500
    2,593
    766
    No, I'm not expecting any increase in MPG with any oil additive.
    There is a certain amount of additives in all stock oils and molybdenum disulfide is one of them commonly used. Adding less than a ounce a quart might likely help.
    I'm NOT sold on the PTFE in Tufoil. It also uses molybdenum disulfide.
    So, I believe that it's the molybdenum disulfide is the most beneficial part of it.
  10. bwilson4web
    16,012
    I'm amused how so many of these after-market additives seem to escape the notice of motor oil blenders. It isn't like I can pay extra and get "<name_brand> with <additive>" at the local Auto Zone.
  11. bisco
    51,154
    big oil does not want these products to be successful and spends millions on fud to undermine them.;)
  12. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
  13. Easy Rider
    982
    210
    N. Central Florida
    Well that's just sad.
    In the US....maybe 40 years ago.....the big "thing" in oil was Arco Graphite.
    It only lasted a few years because of some problems that showed up.
    I don't remember the specifics but a Google search might turn up something.
    I actually used it a couple of times in my '57 Chevy and couldn't tell any difference......EXCEPT that graphite and
    oil mixed together creates a godawful cleanup problem wherever it touched.
  14. Mike500
    2,593
    766
  15. xliderider
    8,056
    3,223
    Honolulu, HI
    BG MOA (Motor Oil Additive) was also popular with Nissan service departments here.
  16. Mike500
    2,593
    766
    If you're one to keep a car for less than 100K moles, I would NOT worry about wear on the oil piston rings.
    Anti-wear additives will show their worth in the 200K plus range.
  17. JSchnee
    For what it's worth, my mileage is still +10% since making these changes. It's been between 20 and 30 degrees F for each of 4 separate commute legs of 50-55 miles each (without grill blocking, car sits out in the cold overnight and at work). If you're reluctant to try Tufoil, at least try Liqui Moly -- if it's good enough for Merc, BMW, etc. it's good enough for me.
  18. ETC(SS)
    6,958
    I remember...:D
    Actually the Molly-be-damned stuff isn't bad for your motor, and the Tuf(on your wallet)oil probably won't hurt it either....but as Mike pointed out, the true benefit won't be apparent until you've reached lunar mileage and even then?
    It's probably a slight benefit.
    Generally speaking, people don't replace engines in cars.
    It happens occasionally when people forget to put oil in the motor or when there is a one-in-10,000 manufacturing error, but even a poorly maintained mill will usually hold together for over 100,000 miles - and by then most cars start exhibiting geriatric problems with suspension, electrical, emissions, transmission or any of a bunch of other things.
    My biggest problem with Snake Oil products are the mileage claims.
    I'm "sure" there are examples of these products working out there, but Toyota sells Priuses for ONE thing.
    MPG!
    If they could add a bottle of snake-oil to the motor and a paragraph to the maintenance manual and suddenly be able to market a 55-Mpg car instead of a 50-MPG car???? :eek:
    They would be all over that like a bum on a bologna sandwich!!!
    In fact?
    They would probably add the snake-oil to their already over-priced designer blend of oil so that their entire fleet would receive a 10-percent bump.
    So......I'm sorry, but I'm a hard sell on the Marvel Mystery Oil scheme.
    No flames.
    Just sarcasm. :)
    Your Car.....Your call.
    YMMV.
    bwilson4web likes this.
  19. Mike500
    2,593
    766
    To me, a half a can of Liqui Moly every oil change at the 10K interval is cheap insurance against wear on the piston rings, especially on the oil sealing ring that would cause oil consumption.
    That's about $4 an oil change.
    I do keep my cars for 10-15 years plus.
    I have no expectations of increased mileage and don't expect it.
    While worn compression rings would cause loss of compression, most power loss due to loss of compression can be attributed to burnt or damage valves, with the exhaust valve being more likely.
    In the old days, tetraethyl lead residue coatings in leaded gasoline protected valves from heat damage. Currently, harder and more durable insert seats do the same.
    So, I do NOT believe any of the other claims, as others assert.
    Your choice!
  20. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    In theory the gasoline choice is not signficant (assuming Regular is used in each case).
    You switched from a TopTierGas.com company (recommended by Toyota due to use of additional detergent additives) to a non-TopTier company. In any case, I am thinking NJ uses EPA reformulated gasoline which would tend to make the Regulars at each station fairly similar with respect to energy content.
    In general, I am thinking energy content variations could account for up to 10% MPG difference, but I am not expecting much energy content difference between two "RFG Regulars" in NJ. What I am doing is measuring density when I fill up to see energy content diffrences. So far I only got one sample...its messy...don't try this unless you are safe.
    We've been seeing some wild swings in MPG lately as Spring warm up attempts to visit DC (10-in snow yesterday though - another set back). The other day we had terrible ~35 MPG in 60 mph winds snowy 0 deg F up the mountains...I was wishing we had grill blocks...do you have that?
