Door adjar light and master caution light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johnbwg00082v, Jun 29, 2019.
  1. Johnbwg00082v
    Johnbwg00082v New Member
    Bend, Oregon
    Four Touring
    09 Prius Touring door ajar light on with master caution on. Unplugged all 5 door switches (no change) plugged them back in one a time and no change. Ran OBD, no DTCs stored???? What?
  2. Patrick Wong
    18,200
    6,479
    Use an ohmmeter to measure resistance across each switch when open and closed. Look for a switch that behaves differently than the others.
    JC91006 likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,330
    6,007
    Columbia, SC
  4. landspeed
    landspeed Active Member
    357
    202
    You have probably already found this, but, the master warning light / red triangle of death comes on when the car is in drive and the driver's door (probably others too) is ajar. So, that may well be why there are no codes. It was scary the first time that happened till I realised why!
  5. TMR-JWAP
    6,330
    6,007
    Columbia, SC
    This gave me heart failure the first time also.....:)
