DOOR AJAR LIGHT ON TURNS OFF WHEN BRAKE PEDAL PRESSED
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Muneeb, Jun 8, 2019.
  1. Muneeb
    Muneeb Junior Member
    22
    23
    SURREY
    Business Edition
    Hi everyone I'm stuck with 10th anniversary prius which has door light on issue but turns off when brake pedal is pressed. Due to this car doesn't lock. I started from rear and checked boot lock and all 4 door sensors(replaced with another prius) but no luck.
    Finally got to the R28 plug on C pillar by rear passenger seats has male connector which connects both sides of female connectors, by removing the female plugs turns the door open light off. Now if I disconnect the plugs then the stop light on boot lid and passenger side brake light stop working. After carefully looking into the car I found out that the car has been accident repaired.
    Please if someone wants to shed some light on this issue as I will be opening this car on monday again.
    Your help will be much appreciated.
  2. ChapmanF
    15,614
    Sounds like a "just keep doin' what you're doin'" situation ... it has been accident "repaired" in a manner of speaking, and you're getting closer to finding the spot you need to find, and with continued investigation, you will.
    Muneeb likes this.
  3. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    It would help if you’d be a little more clear about the car’s year and model. I don’t think my Prius ever displays a Door Ajar message; I get “Key in Vehicle” messages which prevent locking.
    There are two causes I’ve had: Either leaving my key in the vehicle, or not completely closing the rear hatch, which then bounces open slightly and displays a Key In Vehicle message (instead of “hatch ajar” “door ajar” or similar). But maybe your Prius is different from my 2012.
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    The Gen 4 does show door ajar and the MID display shows which door or doors.
    Which door does the display show is ajar?
  5. Muneeb
    22
    23
    SURREY
    Business Edition
    2012 10th Anniversary Model
