Door Compatibility - 2010 Door on a 2014 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Benjamin Goldstein, Aug 20, 2019.
  1. Benjamin Goldstein
    Benjamin Goldstein New Member
    Gainesville, FL
    I need to replace the front passenger side door on my 2014 Toyota Prius (II trim). Only the exterior panel on the door is damaged so all the rest of the parts of the door are intact. I've seen 2010 Priuses being parted out and I want to know if there is any compatibility issue with me replacing my door with one from that year model. For example, maybe there's a slight variation in the hinge from one year to the next and so on. Any help is appreciated.
    49,482
    afaik, they are all the same, but you would do well to look for an on line parts breakout to see if the numbers are the same, or talk to a dealer parts department
  3. schmuber
    schmuber Member
    115
    84
    Georgia
    Yes, look at the major part numbers. Many dealership parts departments will tell you them in person (but not over the phone). Toyota changed a few trim pieces for 2014 (for example, hook placement for the driver's floor mat) as well as some stuff under the hood, but metal parts and hinges for the door are likely the same.
