Door courtesy lights
Discussion in 'Gen 2 Prius Accessories & Modifications' started by hobbit, Nov 17, 2007.
  1. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I mentioned this easy mod in a couple of recent posts, but now that
    I've added a significant safety UPGRADE to the car I feel much better
    about suggesting that folks can remove the little light bulbs in
    the door-edge "courtesy" lights to mitigate the door-left-ajar
    battery drain problem that seems so common. I can leave the doors
    open all day with the car powered off, such as at the car shows and
    energy festivals, without any risk of draining the 12V battery.
    http://techno-fandom.org/~hobbit/cars/dcty/
    _H*
  2. Tideland Prius
    16,159
    I was about to comment on the safety bit then saw you have it covered!
    The reflective bit works well on the rear doors that don't have courtesy lights.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    One of the first things I did to both the 2005 and 2007 Prius was to add retro-reflective tape to the doors and on the bottom of the hatch (visible when open). The next thing I did was change the "courtesy" lights in the doors to side-firing LEDs. I rather like seeing what I'm putting my foot into, so eliminating the door lights wasn't a consideration. Dropping their power use obviously was.
  4. hobbit
    4,089
    468
    Bahstahn
    So where did said side-firing LEDs come from, or did you hack
    something together using the lamp housings?
    _H*
  5. Bill Merchant
    4,096
    82
    Hi Hobbit. I got a set of these LED lamps. No modification of the lamp housing necessary. I replaced all the interior/accessible lamps with LEDs from warden_jp2002. The lamps ship from Hong Kong, so it takes a while to get the order.
    I was thinking of tricking out the signal lamps with chrome bulbs, but sort of lost interest, though I may still.
  6. 8AA
    8AA Active Member
    550
    62
    Maryland
    I bought a set of the flank LEDs for my license plate lights and I ordered a second set to see if I could use them to replace the door courtesy lights. The only modification I made was to wrap a 1/4" strip of electrical tape around lamp between the LED and the terminals. My concern was the proximity of some of the components to the metalic lamp holder in the housing. The electrical tape had an added benefit of making the lamp fit a little better in the lamp holder.
  7. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Bill,
    those LED's look great!! are they really just "plug and play"?? no re-wiring required?? fits in the same socket, etc?
  8. Bill Merchant
    4,096
    82
    Hi Rangerdavid. Yes, those LED lamps just slide right in where you take the bulb out. Usbseawolf2000 started a topic back in March of this year on LED replacements lamps, which see for further discussion. I didn't need to add any tape like 8AA did, but as we all say, YMMV.
  9. Rangerdavid
    1,362
    52
    Three Touring
    thanks Bill ...... :D
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    Nice find. The "flank" LEDs look like they are better suited to the door courtesy lights than the other LED replacements I bought, so I just ordered a pair. I'll use the others to replace the map lights.
