Door Lock Problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Darryl P, Jun 21, 2013.
  1. Darryl P
    Darryl P New Member
    This problem began a short while ago. It started with the keyfob not locking the left (driver) door from the outside and progressed into not locking the left door with the inside automatic switch. Now the left back door will no longer lock with the either device.
    I think I have narrowed it down to the switch or the door solenoid, but I am lost on the possible problem in all honesty. Any help would be appreciated.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    339
    Hawaii
    KK6PD likes this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    The replacement motors are so inexpensive, I bought 2!
    They are safely stashed away in the Prius Kit, ready when I need them.
    Also is a print out of the referenced thread posted by nh7o.
    Bring it on, I can fix it!
  4. prius-walla
    prius-walla Junior Member
    28
    25
    essex UK
    hi
    you could try seeing if you have the same issue as me where my lock stopped working and once i released it i saw that the grease on the lock mechanism (the part visible on the edge of the door which clamps onto the locks latch) had hardened and this was making the mechanism stiff and difficult for the motor to move. i gave the lock mechanism a good clean and regrease and the movement is much softer and smoother now. worth a check
    my thread is below:
    stuck double locked rear door | PriusChat
  5. Darryl P
    Darryl P New Member
    I will try the motor problem, but I do know the 12v battery needs to be replaced. If this battery is weak would it prevent just one of the doors from unlocking or would it be a car wide problem?
  6. Darryl P
    Darryl P New Member
    To continue my previuos thought, I may believe it is the 12v because all of the doors lock fine when in the ready position
  7. nh7o
    1,686
    339
    Hawaii
    The 12V being low will definitely make which ever door has the stickiest grease, the longest (highest resistance) wires, or the weakest motor to act up first.
  8. Darryl P
    Darryl P New Member
    This has been a great help. I will have to locate a battery to replace and hope that solves the door problem.
