Door Locking/unlocking issues?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tatania, Jul 24, 2006.
  1. Tatania
    Tatania Junior Member
    35
    S. Calif
    Have had mine for about 4 days now. LOVE IT!
    I really love the smart key function. Well today I go out to my car and hear the beep of "hello I recognize you"...but when I pull on the door handle the door won't open. Ok fine...so whip out the fob and hit the unlock..door still won't open. Make sure I unlock all doors and sure enough I can now open the rear door and hatchback, but still cannot open the driver side door. I whip the physical key and make sure the door is unlocked which it was. This time I yank on the door and it opens like it was stuck. There was nothing in the door like a seatbelt or anything that would wedge it.
    Has anyone else experienced this? I figure I'll watch it and see, but thought I might ask here to see if this is a 'known' glitch.
  2. Lil Mo
    Lil Mo New Member
    171
    It does not happen on mine. Perhaps you should get it checked?
  3. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    No, this is not right...you need to get it checked out.
  4. marcovi
    marcovi Junior Member
    31
    I have been having the same problem for a few days.. Actually I left my key(FOB) on the handle inside the door where the window controls are and I got lock oouut!! But luckly the door reopen again by touching the handle.
    I had several times to take the emergecy key and open it manually. Also I press the lock button on the FOB and the car doesnt do anything. I am pretty annoyed...
    I have a new Prius 06 #8 (Fully loaded)
    Has anyone else been having this problem?? Any Solutions?
  5. Hybred
    Hybred New Member
    28
    Renton, WA
    Marcovi, I was having similar problems only..sheepishly someone discovered that my long beep and inability to lock my car door was due to the hatch being open! Duh. Sorry wish I could be more help.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i had temporary problems as well but was a neighbors Wireless air station for his cable internet that she was beaming to her son that lived in the apartment across the way. my car just happened to be parked between the two apartments. have since moved from there and have not had a bit of problem since
