Door Open (Ajar) warning coming on when leaning against door
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Craig_T, Sep 27, 2014.
  1. Craig_T
    Craig_T New Member
    Belleville, MI
    I have a 2008 standard Prius. Every time I go around a right hand turn and my body leans against the driver's door the Door Ajar warning light comes on. I've checked for any kind of free play in the door and it seems securely latched. Where is the door open sensor and does anybody have any suggestions about a cause and the fix for this problem?
  2. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Open the door and look at the body frame, look for a black rubber covered spring loaded button. That should be the switch that activates dash panel light and alarm. I can't be precise because my wife has the car now, I looked at our Prius v and it is located near the rear of the frame.
    49,726
    all i can think is that the switch (button) is not pushing in far enough and pressure on the door is enough to release it. hopefully, it's adjustable. funny that it's happening after 6 years, maybe there is some wear or damage.
  4. hchu1
    hchu1 Active Member
    316
    127
    Houston, Tx.
    2014 Prius v wagon
    Check the plastic housing the switch is in, it may have cracked where it is anchored to the frame.
  5. bisco
    49,726
    good point.
  6. Craig_T
    Craig_T New Member
    Belleville, MI
    Thanks a lot. I feel like an idiot. I looked right at that switch and thought it was a solid piece of rubber acting like a bumper.
