Door open always draws 500ma
Discussion in 'Gen 2 Prius Technical Discussion' started by Woodchuck, Oct 28, 2017.
  1. Woodchuck
    Woodchuck Junior Member
    25
    26
    Menlo Park, California
    My kids constantly leave the doors open in our gen 2 Prius and, despite having removed the dome lights, I still find my car dead in the drive every few months. When I do an amperage draw test, I can see that opening a door draws 500ma indefinitely - even with no interior lights on. Is this normal? I would expect it to timeout.
    51,141
    there may be other things the doors fire up. is there a difference between the drivers door and the other 3?
    Raytheeagle and Mendel Leisk like this.
  3. Mendel Leisk
    40,575
    Are there footwell lights, the little hidden ones that light up where your feet go? Any lights in the door?
    I would concentrate on eliminating the problem, just get into a checking routine.
    uart, WilDavis and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    I’m always the last one to leave our Prius for that reason;).
    The wife is the usual transporter of our 2 kids. I have come home from work to find the light on in her new car:(.
    I don’t think our 12v in the RX will last as long as the 12v has in our Prius (8.5 years and counting).
    But that’s what the BatteryMINDer 1510 is for(y).
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Puddle lights?
    Does your Gen II have SKS?
    Raytheeagle likes this.
  6. dolj
    dolj Senior Member
    8,212
    4,180
    Wellington, New Zealand
    Yes, it is, although after about 5 min some things shut down and the load goes to about 200 mA. With a door open the car will never fully quiesce. Normal quiescent load is 20 mA
    +1
    The easiest way to do this, is to lock the car every time. No lock, one or more doors are not closed properly.
    Prodigyplace and uart like this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes probably "normal".
    Having kids "play" in the car is NOT normal though.
    Please get all the drivers in the habit of LOCKING it when parked.......everywhere.
    WilDavis likes this.
  8. Mendel Leisk
    40,575
    I don't lock ours in the garage, cuts down the number of times the car is locked/unlocked by maybe 75~80%. I've heard of locking mechanisms failing, being an expensive fix. But I am hyper careful about door closings.
    The last fail was with grandkids, about 4 years back: got everyone out of the car, was distracted, left one door ajar for about 18 hours. That was enough to take it down to 11.9 volts. I revived with charger, but replaced it 2 years later, preemptively.
    mmmodem and Raytheeagle like this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I don't know if 500 mA is normal but if it's the driver lots of stuff is happening. I wouldn't be surprised if it exceeded that amount. A lot of stuff happens to prep the car.
    If it's the other doors, there is the door switch which is the rubber nubbin in between the doors. There is the courtesy light on the door itself. There are the foot well lights if so equipped. There is the instrument cluster indicator for door ajar. Does that add up to 500 mA. Maybe.
  10. Woodchuck
    25
    26
    Yeah, trying to teach my 6, 4 and 2 year old to be sure to close the doors properly is like trying to train my dog to speak english. My wife is so distracted, and rightfully so, with 3 kids that she often forgets. Oh well, I got the Toyota battery with warranty, so the cost isn't an issue. I have trained my wife on how to use a Noco jump pack, just in case.
    As for the 500ma- I really don't get why it draws so much. I checked at pre-dawn this morning, there are no additional lights coming on, other than dash indicators. No footwell lights, and the dome is disabled. @bisco, the 3 passenger doors do behave differently than the drivers. The drivers door clearly draws much more getting computers booting up, etc. It is like 1a, and goes down to 500ma after awhile. The 3 other doors just draw 500ma, no matter what.
    bisco and Raytheeagle like this.
  11. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I’ve trained my 6 and 5 year olds to slam the door close;).
    Since they don’t know how to control themselves, it worked:).
    Haven’t shattered the glass yet(y).
    bisco and mmmodem like this.
  12. dolj
    dolj Senior Member
    8,212
    4,180
    Do you have SKS and did you have the key fob with you when you walked up to the car? If you did you will not see the lowest current draw, as the car wakes up when you approach the car.
    If you are saying that all doors are closed and your car does not have SKS or you left the key fob well away from the car and you still are seeing 500 mA all the time, then 500 mA is too much and indicates there is something that is not going to sleep. Tracing a parasitic draw is very time consuming. There was a thread here in the Gen 2 forums where a guy detailed his quest tracking down and fixing his parasitic drain.
    Out of interest, how are you measuring the current draw?
  13. Woodchuck
    25
    26
    I have SKS disabled and the test this morning didn’t have a FOB within 50 feet. As for the draw test, I removed the 10mm battery ground and placed my multimeter in series between the body and negative cable.
    iPhone ? Pro
  14. bisco
    51,141
    have we discussed the 12v health yet?
  15. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    We don’t want to steal your thunder :whistle:.
    edthefox5 and bisco like this.
  16. bisco
    51,141
    thanks! if it's original, replace it!(y)
  17. dolj
    dolj Senior Member
    8,212
    4,180
    How would the 12 V, bad or otherwise, cause these symptoms?
  18. bisco
    51,141
    perhaps the doors being opened for a short time is killing a weak battery.
  19. dolj
    dolj Senior Member
    8,212
    4,180
    Even if that is true, it doesn't fix the problem. The source of the constant draw needs to be located and rectified, otherwise the OP will just be replacing battery after battery.
    If the source of the constant draw really is that the doors cannot be secured correctly on a consistent basis, then so be it.
  20. Woodchuck
    25
    26
    Yup. This is my 3rd battery in 3 years. This one is only 6 months old. It is an OE Toyota battery FWIW.
