door open indicator lights up while driving..
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toolbox2014, Apr 11, 2015.
  1. toolbox2014
    toolbox2014 Junior Member
    36
    central OC, CA
    My 5 month old 2015 Prius develops a problem. Once in a while when driving at night, the door open indicator and dome lights will come on for a moment and off right away. I assume it is cause by a loose connection or faulty sensor. Before I take the car to the dealer, is there something I can check?
  2. mrbigh
    3,686
    699
    Long Island, NY
    ????? are all the doors properly closed?
  3. toolbox2014
    36
    central OC, CA
    Yes, all doors & hatchback are properly closed.
  4. Mendel Leisk
    40,584
    Do you have a blanket or similar in the hatch. We had one, tucked under the hatch floor back edge, but it got loose and into the latch. It was causing an audible alarm too: no warning sound in your case?
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Slam the hatch works every time
  6. toolbox2014
    36
    central OC, CA
    I have a mat on the back but it does not cover the latch. That was one of the 1st thing I checked when I notice this problem. The car does beep once when the indicator & dome light come on and it always one beep. One time, the cruise control indicator comes on at the same time even though I did not press the cruise control switch.
  7. mrbigh
    3,686
    699
    Long Island, NY
    I think that your vehicle is "possesed". Take a ride to the exorcist................
  8. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    As gauged by......not just looking but pushing on each door and hatch individually to really be sure ??
    Anyhow, I think the dealer will need to check it out eventually because there might be a switch that is out of adjustment or defective.
    I assume that it does not indicate which door is open ?
    If you put it in D and open a door, does it then say which one is open ??
  9. toolbox2014
    36
    central OC, CA
    By stop the car, open & close the doors with stronger force that what I use to.
    One indicator for all door & hatch.
  10. Mendel Leisk
    40,584
    One of our older Accords, maybe the '86, had a door open indicator with distinct symbols for each door and the trunk. Never seen that since. Progress. :rolleyes:
  11. toolbox2014
    36
    central OC, CA
    The funny part is the Prius's door open indicator is a car with 2 doors. Was there ever a 2-dr Prius? I guess it save them a penny or two to have a 2-dr symbol instead 4.
  12. Easy Rider 2
    1,584
    258
    Ocala, FL
    You haven't been looking very closely. ;)
    I just went and checked. My C has a pictorial of which door/hatch is open.
    So does my Fusion. So did my Malibu. So did my Elantra.
    That's as far back as I can remember.
    Oddly enough, I don't think ANY of them makes any kind of alarm at all if the HOOD is not latched down properly. :(
    mertechperformance likes this.
  13. Former Member 68813
    3,524
    983
    US
    i saw it in 2000 subaru, but not in toyota cars i owned since.
  14. toolbox2014
    36
    central OC, CA
    That is nice that your C shows which door/hatch is open but can you check your Prius Hatchback if it is the same. If you Prius hatchback's indicator identifies which door/hatch is open, I can go back to my dealer and demand a replacement. Thanks.
  15. bisco
    51,155
    my hatch only shows that a door is open.
  16. Easy Rider 2
    1,584
    258
    Ocala, FL
    Do try not to be a tool, box. :)
  17. toolbox2014
    36
    central OC, CA
    No issue tonight with the door open indicator/dome light.
  18. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Prius c has individual door indicators. As do about 1/3 of cars
  19. mertechperformance
    532
    126
    Nor-caL
    My first gen xB had an issue with this when I first got it. Turned out to be a somewhat fickle hatch latch. Never replaced it just made dang sure was fully closed never much if an issue after the first few months of ownership.
  20. Mendel Leisk
    40,584
    That's a step in the right direction, good good. With our hatchback I've had to pull over numerous times, just as we're taking off, find out just which damn door (or hatch) .t is
