Door replacements
Discussion in 'Gen 3 Prius Main Forum' started by Jason Maves, Aug 1, 2017.
  1. Jason Maves
    Jason Maves New Member
    San Clemente
    I got a used 2014 Prius with a dented driver side door. I found a 2015 prius (same color) in the junk yard with a perfect door replacement. My question is does a 2015 door fit on a 2014. Im aware of the color shade difference due to less exposure to light, but if it fits i believe it will still look better. Please help. Thank you in advance.
    I am also privy to hearing about channels where i can access the answer i am looking for.
  2. JC91006
    16,474
    8,393
    Should be a direct fit, just the interior trim might be slightly different
    Jason Maves likes this.
  3. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    2014 and 2015 should be the same. In most respects 2015 was a holdover year while they finalized the Gen 4 for release.
  4. Jason Maves
    San Clemente
    Thanks so much for your help guys. My research indicated the same, but i wanted to get a confirmation from people here.
    I love this site. This community is why i purchased a Prius. No joke. Thanks again!
    Raytheeagle and CNYhybrid like this.
  5. Jason Maves
    San Clemente
    BTW, do you think the interior trim from my 2014 will attach to the 2015 door shell? I didn't even consider it until just now
  6. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
  7. kyoo
    kyoo Junior Member
    40
    bumping this - same situation, curious if you had any tips and how this went for you?
    I purchased a new door also, I'd like to swap in the oem door trim, as well as the tinted window. Not sure if I'll be able to replace the touchless door handle, if that is a swap in or not...
