Door/Window rattle when closing door
Discussion in 'Gen 3 Prius Main Forum' started by Electric Charge, Nov 7, 2012.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    So I noticed that since day 1, whenever I close the door (both driver/passenger side), part of the door rattles, almost like it reverberates. It makes the car feel really cheap, and find it hard to believe that this is normal, since I never heard this with any other Toyota. I'm not sure if it is the window rattling, or the window frame.
    Are you guys experiencing this as well?
  2. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Mine rattles if I shut the door with the window open, but not when it's shut.
  3. Hank101
    Hank101 Member
    108
    SC
    Mine has done the exact same thing since new. It does make the car feel cheap.
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
    When you close the door from the outside, keep you hand on the black molding at the rear of the door window and you shouldn't hear the rattle.
  5. Electric Charge
    545
    133
    Syracuse, NY
    Yea but between being a fingerprint magnet, and being more prone to jamming your finger in there, not sure if that's a good idea. I mostly concerned that something isn't properly installed, but I'll learn to live with it.
  6. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I find you don't need to exert much effort when closing the doors, just a firm tug or push. Sometimes I'll have people riding with me that have to "slam" the door getting in and out, and then it will sound a bit "tinny". :mad: Of course, when they treat my car with disrespect, they're not invited to ride with me again!:LOL:
  7. El Dobro
    El Dobro A Member
    6,979
    3,214
    No, you just push on instead of the door handle and it doesn't rattle. No jammed fingers.
  8. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    If you put some sound deadening material (like Dynamat) on the outer door skins, it will make a HUGE difference.
    My Prius owning friends ALL notice my doors sound and feel different when closed.
    There are quite a few threads about it in the Accessories and Mods forum.
  9. Electric Charge
    545
    133
    Syracuse, NY
    I'd love to Dynamat the car, but it's just a Lease, so not really worth the investment. I also think the problem is with the top part of the door (the black frame which holds glass), which can't 'stuffed'.
