Door won't close and latch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MoscowSam, Feb 1, 2009.
  1. MoscowSam
    MoscowSam New Member
    Idaho, Moscow
    Help, help, help!
    The left rear passenger door will not close on my 2007 prius. :(
    It goes "clunk" and will close not farther about one-half inch before being fully closed.
    The latch mechanism on the outer edge of the door looks about the same, or maybe the same, as for the other rear passenger door when it is open.
    The companion latching piece, on the body, does not look bent nor misaligned.
    There was no "incident" occuring to which I can attribute this malfunction.
    Thank you all in advance.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Are you sure the seatbelt is not caught in the door?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Also make sure that the latch on the door is not cycled into the latched position.
    Tom
  4. MoscowSam
    Idaho, Moscow
    Re: Tom: Yer probably right about latch being cycled to "closed" position. I used a screwdriver blade to manipulate the latch mechanism's orientation. Still, though, it took several tries and with more closing force by me than required on my three other doors. But I did get it to close/latch. I'm due this week for a 20,000 miles service, so I'm going to have them check the latching mechanism and the door's alighment. thank you.
  5. nammie
    nammie New Member
    jacksonville, fl
    Mine did the same a couple of times. All you need to do is push the button on the latch (the one you use to open the latch) to unlock the latch and try to close again.
