Dots on my map
Discussion in 'Gen 3 Prius Main Forum' started by Porky Pine, Feb 11, 2010.
  1. Porky Pine
    Porky Pine New Member
    86
    Newtown, Ct
    I've noticed lately that my nav-map has been marking any route my car takes with a series of dots on my map display. This is for anytime I take my car out and does not only happen if I use the route guidance. It's like my car is leaving a trail of bread crumbs wherever it goes. I'm assuming that it's some option that I turned on by mistake recently as I hadn't noticed it before. Is there a way to turn this off?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It can be turned off. You have accidentally asked your Nav system to record the route. I'm not familiar with the details of the Gen III Nav, but one of the Nav menus will have a toggle for something like "record route", "route trace", or "trace route".
    Tom
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    It's indeed route trace. I did one for my commute to work hoping that it could be leveraged in directions, but it just shows where you've been. You can turn this off and delete the dots from the same screen, though exactly which one escapes me (it's a soft button from the main screen).
  4. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Yep,
    It's Hansel and Gretel in your Navi, seriously. On the main MAP screen on the bottom left is a touch button just to the right of the ZOOM icon (+).
    Touch that button and one of the options that will be lit up is 'ROUTE TRACE'. If you're lost it leaves bread crumb markings on the roads you've travelled.
  5. Porky Pine
    86
    Newtown, Ct
    Got it. Thanks.
  6. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Indeed, I've heard them called "breadcrumbs" for that very reason.
    I wish the Nav system would recognize said crumbs and assign a higher priority to roads that have such crumbs on them. It frustrates me that my NAV system picks odd routes when, if Navlady had ANY intelligence, she'd clearly see that I prefer certain roads. I mean really, what is with that woman??? I guess she just figures men don't ask for directions or read maps?
  7. hill
    8,181
    ok - sorry for reactivating this zombie thread. my carpool partner had this happen and he had no idea how to clear it. Good info. It may be noteworthy that this feature is absent from Gen I and Gen II. I see why. Seems kinda like it's a lame feature. I find it hard to believe that the purpose is to put markers as you travel a road that you're lost on. Why wouldn't you just put in an address where you want to go, or any other saved marker .... or just tap a spot where you want to end up at? Who wants to travel back on a road that you shouldn't have gotten on to in the first place? If you pick a waypoint and it happens to take you back that way ... fine ... otherwise ... who'd need dots.
    #7 hill, Dec 5, 2014
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    What are you talking about? This is one of the feature I use all the time. When I went to LA last week, I went through a maze to look for restroom. Luckily I was able to retrace the route back to the freeway from the dots on the map.
  9. GregP507
    GregP507 Senior Member
    3,002
    480
    It's quite a useful feature, and it can save your bacon occasionally; finding your way out of a convoluted cul-de-sac, or a backwoods goat-tail, or even finding your way back to that friend's place that you visited 6 months ago but can't remember how to get there.
    The Garmin M4 (long since discontinued) did it one-better. It left a trail of dotted lines everywhere you went, but when you retraced your path, it laid down another line parallel, so that if it was a route you took 10 times, you had 10 parallel lines along the route, which was a bit much I thought.
  10. cproaudio
    2,401
    759
    CA
    This only works if you plan on driving less than 100 miles in 6 months. The dotted trail is only about 100 miles long.
  11. GregP507
    3,002
    480
    Different settings for different rigs.
  12. cproaudio
    2,401
    759
    CA
    So you're telling me that there's a setting to lengthen the dot trail? The trail is 100 miles long on my Prius and my Sienna. I doubt it's different for other Toyotas.
  13. GregP507
    3,002
    480
    Maybe not other Toyotas, but on one Garmin I had, it stretched out for years.
  14. cproaudio
    2,401
    759
    CA
    I believe the OP refer to the OEM Toyota nav. If it stretches out for years then I can see it being a problem as the map would be cluttered with traces. Also there's the privacy issues. Anyone that has access to your GPS device can see where you've been for the last year or 2. With Toyota, the most they can see is the last 100 miles.
  15. GregP507
    3,002
    480
    And it was.
