Double flash gas gauge on combo meter?
Discussion in 'Gen 2 Prius Main Forum' started by Tj S, Sep 18, 2016.
  1. Tj S
    Tj S Member
    34
    33
    Oceanside, ca
    Can anyone tell me what my prius is trying to tell me when the gas flashes twice liked this:
    My troubles started when I replaced my combo meter on my 280k mI car due to it blacking out on a drive.
    I bought a refurbed combo meter from a repair shop in LA. The guel gauge flashes after starting starting the car and driving a few hundred feet. I took it apart several times and checked my connections with no resolution. I had the shop send me a second combo meter and same double flash. .. I reinstalled my original combo meter and is flashing now too. I carefully checked the flex cables behind the combo and didn't see anything.
    I replaced my marginal 12v battery, reset maintenance interval, recalibrated fuel gauge and will replace flex cables when I get back home.
    Does anyone have more ideas? It feels like assembly error or poor connection since the original is doing it now. Dealership wants 700 usd to install a new meter, but I may have to do this ad I don't trust the fuel level.
    #1 Tj S, Sep 18, 2016
  2. zorch
    zorch Junior Member
    Did you ever figure this out? I did the same thing...
    52,375
    defective?
  4. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    We've had the blinking fuel gauge on a couple of DIY installs in the past and it's always been caused by a disconnected inclination sensor. The six pin plug (circled in red) feeds into two sensors that are under the white plastic cover (boxed in yellow). If during the disassembly/assembly that wire gets pulled on it can come unhooked from one of the sensors under the cover. Because that cover doesn't get removed during the meter install the disconnection will normally go un-noticed.
    Take the dash out and check that the inclination sensor connection to the meter is firmly seated and then remove the cover from the sensors and make sure that they are both plugged in. Once it's back together park the car on a level surface and do a zero calibration on the sensors and that should get it fixed. I've uploaded the calibration directions in case you don't have them.
    Matt
  5. Tj S
    Tj S Member
    34
    33
    Oceanside, ca
    Matt: Thank you so much for the tip. I was able to resolve the double flash fuel guage. It was a loose connection under the cover just like you described. I lived with that for 3 years and now the guage is working! THANK YOU!!!
    SM-G960U ?
  6. ChapmanF
    18,533
    For anyone else facing such a three-year ordeal, there is a repair manual (more info) that includes a section on the different gas gauge blink patterns and what they would be telling you.
  7. Name:
    23
    Salinas, CA
    I don't know how you figured this out, but I am going to try it! Thank you very much. I've searched far and wide, and this is the first answer that addresses the situation directly.
    #7 Name:, Jan 8, 2023
  8. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
  9. Name:
    23
    Salinas, CA
    Sure enough, the issue is solved. Those two connectors under the cover don't have tabs and pull out easy. I took a picture, enjoy.
    PS: Do not forget to reinstall the two 12mm airbag bolts.
    #9 Name:, Jan 9, 2023
    Kasra likes this.
  10. sabotta
    sabotta Junior Member
    Olympia
    I've checked the Repair Manual for the 2008 Prius on the Chilton Library site, but the repair manual never refers to "the different gas gauge blink patterns". Are you referring to a different year for the Prius?
  11. ChapmanF
    18,533
    Well ... apparently I was. I was familiar with the Gen 1 repair manual, where on page DI-661-1 (in the 2001 edition), the whole page is about fuel gauge blinks.
    In that generation, there were two choices for blink pattern (a steady, 1.2 second period even blink, and a double blink that repeats every 2.4 seconds), and two choices for which segments do it (all the segments, or the display segments plus E), leading to four possible combinations.
    If it's the steady even blink and all segments are doing it, there's a communication problem between the meter and the ECM or the body ECU. If it's the double-blink and all segments are doing it, it's a fuel sender issue.
    If it's the even blink and display segments plus E are doing it, it's a fuel temperature sensor issue, and if it's the double-blink and display segments plus E are doing it, it's an inclination sensor issue.
    So it seems like the Gen 2 speaks pretty much the same language (in the video in post 1, it's the double-blink pattern, and looks like all the fuel segments plus E and F and even the MI indicator for miles on the odometer), and it did seem to be an inclination sensor issue.
    So it kind of surprises me that a Gen 2 repair manual would be missing that information that was in the Gen 1 book. But I looked in an old 2006 edition and you got me, I didn't find it there either.
    In the 2001 Gen 1 book, the strange page number DI-661-1 looks like a page that was inserted at the last minute (between 661 and 662). Maybe they also lost track of it when preparing the Gen 2 editions. :( (Or maybe it got moved somewhere else in later editions. @Elektroingenieur might know. On the techinfo site, I once used the comment feature to report a missing bit in a manual and they did respond to me, so they do watch for that kind of comment.)
    Oh, that page also describes one more blink pattern that isn't a problem. If it is just the bottom fuel segment blinking and it's the steady even blink, the car has just been powered on after battery power was out for a while, and that segment will blink until the gauge has figured out what the fuel level is.
    #11 ChapmanF, Mar 30, 2023
  12. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    Mine was not unplugged; it just wanted me to redo the job, and magically worked. Thanks for pictures
  13. lexidium
    lexidium Active Member
    301
    143
    manchester
    Isn't this a wonderful forum . . .
    You could go a lifetime and never find that out.
    Keep up the great work guys.
    Kasra likes this.
  14. mke039
    mke039 Junior Member
    25
    Massachusetts
    Just polished the heads up lens on a used gen II I bought which required removing combination board and had this problem after reinstalling. Sure enough that hidden connector had come off. Thanks to this thread it was an easy fix
  15. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Just put my dash back together and getting the double flashing light.
    First half decent day I have, I will have to check again.
    At least the cluster seems otherwise working
  16. dolj
    dolj Senior Member
    8,553
    4,344
    Check both ends of the cable shown in post #4 are plugged in fully.
  17. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    I filled up the tank because that gives me 350 miles before I have to worry about unreliable readings at least.
    I think I might be able to take everything apart Sunday.
    Now that I have done it once and still have the video, should be easier.
    Thank you for this forum though.
    #17 KitsuneVoss, Jan 10, 2025
  18. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    I was too tired Sunday to work on the car in any serious way but today I was able to take apart the dash again.
    I must not have pushed the connector in hard enough because it cam loose while I was messing with it.
    Plugged it in and drove to Walmart and the odometer was no longer flashing.
    mr_guy_mann and dolj like this.
