Down shift when accelerating
Discussion in 'Toyota Hybrids and EVs' started by HC1, Dec 26, 2016.
  1. HC1
    HC1 New Member
    US
    Hi..for the past month now my 2011 prius is down shifting for a second or 2 .It pauses then it catches the power..i have 167k on it..any advice??
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    A professional diagnosis will probably be required.
    If the transmission fluid has never been changed THAT might be a good place to start.
    And I think it is more likely that something is slipping.......because I don't think they have conventional type "gears".
    Could be a problem with the TPS (throttle position sensor) too.
    49,694
    welcome! start by making sure you have done all the required toyota maintenance to date, according to your owners manual maintenance schedule.
    then, move on to things that are not in there like, throttle body and maf sensor, pcv, intake manifold, injectors and etc.
