Down to 2.37 kWh per charge
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Nov 27, 2018.
  1. markabele
    5,084
    1,782
    Nebraska
    That's all I'm putting in the car each time I charge now. Anyone remember what the amount was when we bought these things?
  2. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    4 kw, usable from 80 to 20%, so 60% from 4kw = 2.4kw net
  3. markabele
    5,084
    1,782
    Nebraska
    I believe it was like 3.3 kWh, not 4.
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    It's 4.4kw, actually
  5. markabele
    5,084
    1,782
    Nebraska
    You are correct. Just found that number myself.
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Once it gets above 10 kWh, my meter reads in round kWh numbers, so I only see it when I reset my meter after getting gas. I think it's usually around 2.4 or something like that when charging from a depleted EV range. And, of course, that will depend on how deeply you've dipped into the HV portion.
  7. bisco
    49,402
    i'm down to 10 miles ev range from 15 in summer, no idea on kWh.
  8. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    I tested my 2014 and the most I could put on was 2.5 Kwh on the slow charger, looks about right if you get about 4miles per kwh, my leaf gets about 4.5 m/kwh per comparasion.
  9. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Start 21.9%
    Full 84.7%
    Difference 62.8%
    Charge kWh 3.1
    Assume efficiency 90%
    Calculated total capacity kWh 4.44
    10/10/18
    Start 23.1%
    Full 84.7%
    Difference 61.6%
    Charge kWh 2.66
    Calculated total capacity kWh 3.89
    Percent of original capacity 87.4%
    If the 90% efficiency is a reasonable estimate you can't actually charge more than about 3.2 kWh on a new battery because of the approximate 20% to 85% range
    As for miles estimate shown on a full charge it very much depends on your type of use. I live on a hill and recently pretty much always use HV mode on the way home. So the display estimate is around 15 miles even in the winter. Of course that isn't accurate. On level ground at a modest speed I would probably only get around 10 - 12 miles in EV.
    markabele and Yea Right like this.
  10. bisco
    49,402
    agreed. i do the same driving all the time, so it's pretty accurate. i wish i had a gauge. if i'm down about 15% from new, that would be around 3.74kwh currently?
  11. CaliforniaBear
    1,179
    289
    Northern California
    Yes, sounds about the same as mine. While the number of miles you can get on a full charge is nice I find the great gas mileage on longer trips to be very satisfying. Our trips generally involve some back roads and hills. With the ability to use the downhill to recharge the battery we generally get almost 60 mpg on a 2 or 3 day trip.
    jerrymildred and bisco like this.
  12. markabele
    5,084
    1,782
    Nebraska
    Thanks for the stats. What are you at for total miles? EV miles? Done any mountain driving where you fill the pack in 5-10 minutes?
  13. CaliforniaBear
    1,179
    289
    Northern California
    Total EV miles 18,879 shown on the display. I don't keep track of the display kWh because I don't really know what it means. The power line usage is 3980 kWh. That's an overall 4.7 miles per kWh if all miles came from power line charging. Since we expect to get 12 EV miles for 3 kWh of charge (4 mi/kWh) the breaking charging provides about 0.7/4 = 18% of the EV miles.
    Yes, I live near Sacramento so some trips are over the mountains. Most of our trips are to the coast with less quick full charging.
  14. freshfuel
    freshfuel Junior Member
    brookfield IL
    when I use charge point it says my charge taken was about 2.4 kwh. I have a 2012 with 90000 on the clock and currently I am getting 9 miles winter temperature range
