Dr. Prius can't see bluetooth connection on Iphone
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gjkristi, Jan 11, 2026 at 12:37 PM.
  1. gjkristi
    gjkristi Junior Member
    38
    Dr Prius issues. Purchased a Panlong OBD2 Scanner Bluetooth for iPhone iOS Android OBDII Car Diagnostic Scan Tool Engine Fault Code Reader.(Which works on other APP's IOS) but I'm getting an error when in the APP (Connect OBD) please able bluetooth. It is abled and works on other APP's. This is an I phone any ideas? Thanks Gregg
  2. jacktheripper
    jacktheripper Senior Member
    271
    540
    Hi Gregg,
    Two things to try:
    1. Re-install the App and this time make sure to "Grant access to nearby wireless device".
    2. Make sure you only have one OBD2 App running at a time, otherwise two OBD2 Apps will be fighting for bandwidth and timeout.
    hope this helps,
    Jack
  3. gjkristi
    38
    Thanks will reinstall
  4. BiomedO1
    BiomedO1 Senior Member
    3,791
    1,971
    SacTown, Ca
    People also forget to disable their car audio interface, smart watch, air tags and anything else using the Bluetooth bandwidth. Your Bluetooth has to pick through all that interference to find that new device. Best to disable everything else so your phone can find the device faster and easier.
  5. indel
    indel Member
    191
    72
    Northwest Indiana
    While not a dealbreaker, Panlong does not support Apple's bluetooth 4.0 connection. So it relies on 3.x and below, which may not be as good.
    Cornvalue likes this.
  6. Mendel Leisk
    41,644
    I've used a Carista OBD Adapter, no problems.
