Dr. Prius Green vs Yellow bars
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Oct 8, 2025 at 4:58 PM.
  1. qmanqman
    qmanqman Active Member
    386
    123
    CO
    With Dr. Prius running while driving, I noticed that when I hit the brakes the bars turn yellow. If you google what yellow and red means, the Google AI tells you it's an indication of the battery's diminishing life.
    If you then Google "what does it mean tha the voltage bars on the dr prius ap turn from green to yellow when I brake" you get this:
    AI Overview
    When the voltage bars on the Dr. Prius app turn yellow while braking, it indicates the car is using the hybrid battery to regenerate energy, not the main 12V battery, and is a normal function. The change from green to yellow is expected because the system is in a different operating mode, converting kinetic energy from braking into electricity to charge the hybrid battery.
    • Normal operation: When you brake, the hybrid system uses regenerative braking. This process converts the energy from slowing the car into electricity to recharge the hybrid battery pack.
    • App interpretation: The app is showing that a different part of the hybrid system is now active. The color change on the voltage bars is simply the app's way of indicating that the high-voltage battery is being used to charge, rather than the car's conventional 12V battery, which is the source of the green bars.
    • What to expect: It's normal for the app to show different colors and readings depending on whether you are accelerating, cruising, or braking. A healthy system will have different bars lighting up or changing color as the car's power source shifts from the 12V battery to the hybrid battery and back again.
    I know that's a lot of words but what does this mean: "the car is using the hybrid battery to regenerate energy, not the main 12V battery?"
    1. How does the car use the hybrid battery to generate energy?
    2. When does the the car use the 12V battery?
    3. I thought the car used the brakes to generate energy and store it in the battery.
  2. Brian1954
    Brian1954 Senior Member
    2,024
    791
    South Central PA, USA
    It means that Google AI got it wrong!
  3. qmanqman
    386
    123
    CO
    LOLLL . . . that's was my initial thought
  4. ChapmanF
    17,820
    Yeah, the AI bot wrote in a very confident style while clearly not knowing what it was talking about.
    Which isn't a lot different from the occasional human poster on PriusChat. :D But it seems funnier and more innocent when an AI bot does it, since we kind of don't expect the bot to really know what it's talking about, anyway.
