1. LibTech
    LibTech New Member
    Today
    Bend, OR
    New (to me) prius owner here! Just got the Dr. Prius app a month ago, as I'm getting the dreaded P0A80 code, I knew it was probably coming sooner or later, but not two months after getting this car. It's a 2011, the battery has theoretically been worked on before, meticulously maintained and generally in great shape. Wondering if anyone can decipher what the visual is saying? I have read that the middle section is where you want to look and that higher numbers mean more likely cells are failing, they all seem good to me from here? This was at idle, hadn't been driven in an hour or so. Is that correct?
    Planning on getting into the battery soon and checking out the bus bars and battery fan, etc. Any more ideas are welcome!
