Dr Prius results Help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Taz43, May 28, 2022.
  1. Taz43
    Taz43 Junior Member
    47
    Los angeles
    So i have no codes popping out. Need to figure out how the battery is before deciding to sell the car or keep it. Any help would be appreciated.
    Car has been idle for months. Runs good now but put in dr prius and all the internal resistance bars on the botton are showing yellow at around 33 while driving and 1 hitting 38 and turning red. Volt differential is about .4 and im still getting about 50 a gallon.
    For some reason attaching the pics is failing so i am unable to upload them. Any thoughts please on the condition of the battery.
    #1 Taz43, May 28, 2022
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    In Los Angeles there are likely many places to get the cells in the battery rebalanced off you are unable to do it yourself. Maybe some PC readers who live there will suggest a specific one.
  3. Taz43
    Taz43 Junior Member
    47
    Los angeles
    Okay here are the snapshots, does this look bad?
  4. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    #11 looks to be at risk. What year and how many miles on your Prius? Have you run the Dr Prius battery health and life expectancy tests?
  5. Taz43
    Taz43 Junior Member
    47
    Los angeles
    Its a 2008 Prius with 140k. But the battery is a new one i put in 2 years ago. But car been sitting idle for 8 months after catalytic stolen. Except turning it on a driving it like 2 or 3 times. Now its fixed and everything is good, just wondering if i should sell it or battery is still decent. Can the idle time have messed up the battery? Im still getting 50 a gallon.
  6. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    When you say new, do you mean a new OEM battery or some kind of remanufactured/rebuilt/reconditioned battery?
    Looking at your screenshots and comparing the 18.98 Amp discharge with the 14.81 Amp charge images, nothing stands out as too bad. They just seem to be a bit unbalanced. So, a solid round of reconditioning might be in order to balance that up.
    The IR of block 11 is a little up there, but the block seems to be otherwise no worse than the others.
    If you do a recondition, rescan after and see what it looks like then.
    If you're not intending on keeping it for the long term, I'd sell it sooner than later with full disclosure.
