Dr Prius results! magic 8-ball says, outlook not good.....
Discussion in 'Gen 2 Prius Technical Discussion' started by Ianmeister, Nov 30, 2019.
  1. Ianmeister
    Ianmeister Active Member
    316
    318
    Meridian Idaho
    Hey all!
    So I sprang for the Dr. Prius HV battery analyzer app for my 2006 with 220K miles. A little background first. I bought it last may (cheap) knowing full well the battery was suspect. I talked in another thread about how I discovered that the num num head that worked on the battery last time left out like 90% of the battery bolts. Yes that's terrifying I know. NO WARNING LIGHTS AS OF NOW.
    Anyway, the Dr. Prius App came back with "pass" and "bad balance on blocks #11 and #12". Next I ran the life expectancy test twice. First time It came back "23% remaining, replace soon". Second time it came back "49% your battery is in poor condition but will still run."
    SOOOOO my query to y'all is, Pro-long, or replace? I'm torn between the whack-a-mole option of replacing blocks 11 and 12 and getting a prolong re-conditioner (cheaper option and reusable) or going for newpriusbatteries.com (and possibly throwing away a battery that with help could run a couple more years)?
    whats the consensus all? Go!
    Ian, Fremont, CA 2006 with 220K miles.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Just from that info, it sounds to me like your battery is a good candidate for a Prolong, but it's still a bit of a gamble. Is your Fremont in California or Nebraska. If in CA, there may be someone in your vicinity who could loan or rent you theirs and then you'd only have to buy a cable for it to see if it helps. If it helps, then maybe spring for a Prolong. If it doesn't help, you won't be out as much money.
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    It comes down to the most basic question... How long did you plan to keep the car ?
    Here in Minnesota, where the seasonal changes push people to replace at that point anyway, it's an easier decision.
  4. Ianmeister
    316
    318
    Meridian Idaho
    I intend to keep it indefinitely. I’ll refurb systems myself as they come up. It’s cheaper than the depreciation of a new car by far, plus I don’t mind the effort, I relish it. She’s nice and straight, no rust whatsoever, interior is perfect.
    Leaning towards new battery so far
  5. Ianmeister
    316
    318
    Meridian Idaho
    Hey Jerry. I’m in Fremont California halfway between San Jose and SF. Not a bad idea at all.
    jerrymildred likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree that the decision should take into account what your long term goals/plans for the vehicle are.
    You say you bought it cheap, last May, knowing the battery was suspect.
    Basically Dr. Prius app results included, nothing has really changed. You still own a soon to be 14 year old Prius with 220K miles on it, and a Hybrid Battery that is suspect.
    So it's kind of a No Answer, Answer, but I have to ask what do you want to do?
    I'm not saying this is your case, but sometimes I think people know what they want to do, but will end up at Prius Chat asking the community what they think they should do, really looking for validation or permission to do what they want to do.
    If I'm reading your post correctly, you've narrowed it down to these options.
    Replace blocks 11-12 and buying a prolong system.
    or
    Replacing the battery at newpriusbatteries. com. My understanding is that these are Battery Kits, and require a level of DIY investment.
    Both options come with risk, and cost.
    But it all leads back to what do you want to do?
    Some people really want to DIY. In which case replacing battery blocks, and using the prolong system is just part of the "hobby" or the journey they really wish to take.
    Even the battery kit, represents a desire to DIY.
    I think if you are aware of the risks, rewards, of either choice, than either choice is valid.
    I would say the prolong choice? Is what it's named. At best? You replace the battery blocks, use the system, and get X more life out of the existing battery. Hopefully prolonging it's life.
    Obviously replacing the battery is more an attempt to add significant life to NOT having to worry about the battery. But I haven't got much direct long term feedback about the success or failure of these battery kits. Just saying I don't know here. But you're NOT buying a brand new OEM battery. So I would say, there is some risk in going this alternative route. Maybe others can offer better feedback about this specific choice. But ultimately...
    The choice is yours.
    Merkey likes this.
  7. Prodigyplace
    12,487
    11,731
    Central Virginia
    I believe @Raytheeagle is in that area with the Prolong system? If you choose to replace the battery, the kit of new cells from @2k1Toaster here is cheaper than a Toyota battery. The link is in my signature. You can even sell your tired, not yet failed modules to recoup some of the expense.
    jerrymildred and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    When I moved to the Prime, I gave up my co-ownership;).
    Now it’s @SFO and @The Critic that pull the trigger on the equipment(y).
    jerrymildred, SFO and Prodigyplace like this.
  9. Mendel Leisk
    41,149
    What about the Prolong harness? There's some time and expense involved in installing that.
    Raytheeagle likes this.
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Once that’s installed, it’s easy to share;).
    The equipment sits idle most of the time anyway:).
    Why not make some good use of it(y).
    jerrymildred, SFO and Mendel Leisk like this.
  11. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    I am in Clayton, CA so I can certainly meet up with you for the equipment. If you plan to keep the vehicle, a new battery makes a lot more sense. The cost of the dealer batteries is around $1700 w/exchange and is a much better long-term solution if you plan to keep the Gen2 for a long time.
