Dr prius says good battery 87% life, but 4 of 9 banks at 17 volts vs. 30s
Discussion in 'Gen 4 Prius Technical Discussion' started by Prius truck, Oct 13, 2020.
  1. Prius truck
    Prius truck Junior Member
    Banks 1 and 2, 8 and 9 are about half the voltage of the remaining 5 it's interesting to me that it seems symmetrical how the center banks on the display are all good and 2 on each side are much lower anybody else with this experience?
  2. silent_20
    silent_20 Junior Member
    2015 Prius c
    I had the same question a couple of weeks ago. This is the response I got from Dr Prius "The display is correct, Toyota is cutting cost on the number of sensors on Prius Two therefore you will see 4 blades in a block in the middle section. However all the features have been compensated for this difference."
