Dr.Prius
Discussion in 'Gen 3 Prius Main Forum' started by Rick Silberman, Oct 17, 2023.
  1. Rick Silberman
    Rick Silberman New Member
    Grass Valley, CA
    Does anyone have experience with the Dr.Prius app hooked up to an OBDII bluetooth sensor to test the strength of the hybrid battery? Did you test your battery? Were you satisfied that the App gave you accurate results?
  2. Tombukt2
    Tombukt2 Senior Member
    13,340
    2,401
    Durham NC
    People seem to be pretty happy with it generally speaking I've never ever tested my battery at all I don't want to know about it till the battery's about to fail That's usually about 10 11 years generally if you're dealing with the Toyota battery so I don't really even with the Toyota software that I have I rarely look at the state of charge or any of that stuff as long as I'm seeing green and blue on the energy monitor and almost never magenta unless the air conditioner's running in a parking lot You're in good shape.
    52,349
    how would you know if the app gave the correct results?
  4. Rick Silberman
    Grass Valley, CA
    It said everything was ok and the battery died soon thereafter.
  5. bbrages
    bbrages Member
    166
    47
    St. Louis
    If I remember right, I ran it once on my 2010 and it said my battery was "ok" and at 55% capacity. Then, I ran it a week later and it said it was a bit weak at around 45% capacity. My son's car has a 2017 Toyota replacement battery and tested out at around 85%.
    I think the results will vary a bit, but I also think it's probably the best (easy, cheap) tool out there for getting a picture of battery health.
    To the OP, what were the results from Dr. P when you tested it?
  6. ASRDogman
    ASRDogman Senior Member
    7,792
    3,976
    According to all the various result written on prius chat, that dr prius app doesn't
    seem very accurate for reading the hybrid battery.
  7. bisco
    52,349
    Batteries are like people. One minute you’re healthy as a horse, the next day you’re at the wake
    Kromis, Grit and vvillovv like this.
  8. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    There are temps both (ambient and battery) that can change the test results.
    Don't run the tests when the temps are below 70 F or above 90 F. or if you do scale the results.
