Dramatic change to front bumper; Lexus inspired
Discussion in 'Gen 2 Prius Accessories & Modifications' started by SunDevilDrake, Mar 25, 2016.
  1. SunDevilDrake
    SunDevilDrake Junior Member
    58
    Gilbert, Arizona
    Mock up of plastidip or vinyl to modify the look of the Gen 2 front bumper. Inspired by the look on the newer Toyota/Lexus models.
    Sergiospl likes this.
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Will need some more grill lines or honeycomb, no?
  3. SunDevilDrake
    58
    Gilbert, Arizona
    The intention isn't to make it look like a Lexus but to use the Lexus look for inspiration. Adding honeycomb would be too much work.
  4. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Did you go thru with this transformation yet?
  5. SunDevilDrake
    58
    Gilbert, Arizona
    No and I may not. Don't want my car to be too different since I use it for business to business sales.
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Do the plastiDip, if you don't like it, just peel it back off! (y)
  7. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Chrome strips to highlight lower grill a bit?
    SunDevilDrake likes this.
  8. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Interesting. Unfortunately plasti-dip is a not a good choice for leading edge applications as it will chip, pit, and peel in no time. If you like the mockup, best to consider paint/clear-coat.
  9. SunDevilDrake
    58
    Gilbert, Arizona
    Wouldn't vinyl be simple enough to apply, durable, and removable?
  10. fotomoto
    5,629
    3,802
    So. Texas
    If we're talking DIY and you're not experienced, it can be very tough to apply around complex curves and angles. Pro's make it look easy. Vinyl will still chip but it's way more durable than plasti-dip. On the front, you'll see the most wear the lower you go so it may not even bother you.
    It will also depend on your typical driving environment. If you're a city driver, vinyl would do fine. If you're a highway driver with cars typically right in front of you, it will see much more wear.
  11. SunDevilDrake
    58
    Gilbert, Arizona
    I didn't find vinyl too difficult to work with when I vinyl wrapped multiple interior pieces in the Audi I used to own. But I had the luxury of taking off the parts to work on outside of the car.
    To make this front bumper install right I'd assume it's best to at least take off the lower grille and maybe the upper grille.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    The middle grille trim comes off but the center piece doesn't. Under the trim is a section of the bumper the trim screws to. Don't think taking that off would be much advantage. Taking off the lower grille would definitely help. Heck, taking the bumper off completely might help better.
  13. Pruis-er
    Pruis-er Junior Member
    this one's interesting
