Dramatic improvement in mpg after installation of Engine Block Heater
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Ole Petter, Mar 20, 2014.
  1. Ole Petter
    Ole Petter Junior Member
    Flekkefjord, Norway
    After Toyota installed an Engine Block Heater in my Plu-in, I have gotten much improved mpg numbers. In fact the mpg on shorter trips to town and work (some 3 to 5 km) is halved :) This is when the weather is cold and I need to have heat in the coupe. The first week after the intallation the mpg was 117 mpg. After some longer trips the next weeks saw 78 mpg.
    As spring approaches, I look forward to driving the car in pure EV mode as much as possible. That means all my commuting and trips with the kids to activities and such
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    How much does it cost in energy terms to use the heater, versus the difference in gasoline costs?
    49,387
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    Is this installation option specific to European models?
  5. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I've never seen such happiness at having one's fuel economy halved! ;-) I'm guessing you mean it's doubled...? Anyway, I came up with a jury-rigged battery-powered heater that lets you have a little heat without running the engine. It would work especially well for trips as short as the ones you mention. If you're interested, look for the 'Heater In A Box' topic.
  6. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    No - you can also self-install the Toyota block heaters. I did mine and like it. Many EBH installation threads here. The engine has a cast tunnel sleeve for the EBH on its backside, by the cabin firewall.
  7. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    OP is in Europe, where they measure economy in L/100km, the inverse of how we do it, so actually halved is what he would witness. The strange part is he said "mpg"... and then listed distances in km... ;-)
  8. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    Dumb question, what needs to be warmed or heated?
  9. Will Stewart
    Will Stewart Junior Member
    45
    Northern Virginia
    2014 Prius Plug-in
    Not a dumb question. As a pretty safe engineering guess, I would say the engine block (which affects the coolant temperature) needs to be warmed in order to increase fuel economy and provide cabin heat (via the coolant).
  10. acceleraptor
    acceleraptor Member
    228
    75
    Milpitas, CA
    2014 Prius Plug-in
    Wait. The pictures I've seen of the EBHs all have power cords with what look like normal 120v plugs, which I assumed needed to be plugged into wall power.
    Is there a way they simply run directly off of the car's electrical system and then automatically shut off after the engine block has reached operating temp?
  11. GregP507
    GregP507 Senior Member
    3,002
    480
    Block-heaters are standard equipment on all cars here in Canada. I see it as a trade-off between paying for several hours of electricity consumption by the block-heater versus 3-4 minutes of running the engine to warm it up. Since my Prius came with 0-W20 grade synthetic engine oil, cold starts are not much of an issue, and I rarely see the need to plug in the block heater.
  12. Mendel Leisk
    38,651
    The block heater is 400 watt, and a couple of hours is sufficient use, get's the temp near the point that it stalls, doesn't climb any more.
  13. Mendel Leisk
    38,651
    It maybe on the prairies, sadly not in coastal regions. I really think it should be a factory install, guess it would take legislation. The part is pretty cheap, it's the install cost that hurts. With the Prius at least no coolant is drained, but other manufacturers, Honda in particular, immerse the heater in coolant, and the coolant is drained/replaced (ridiculously early) when the dealership does the install.
  14. GregP507
    3,002
    480
    There are a few problems with that idea: The Toyota block heater uses 400 watts of electricity for at least an hour to achieve much effect. To drain that much electricity from the car battery is far less efficient than running the engine for a few minutes to warm it up. The Prius GenIII uses a heat-recovery system built into the exhaust system, which I find will warm up the engine in 3-4 minutes in cold weather. Secondly, the battery voltage is wrong to run the block heater.
    An idea which has been brought up here before is to interconnect the interior heater with the charging cable. Perhaps a block heater could be incorporated into that as well.
    acceleraptor likes this.
  15. GregP507
    3,002
    480
    I stand corrected; dealers here have always added the block-heater option by default, but I can understand the reason for not having it installed in the Lower Mainland, where the price of it is a small competitive price advantage (and a great money-making opportunity for installing it).
    Personally, I rarely use block heaters, because I find that the winter-grade synthetic engine oils make it unnecessary.
  16. Mendel Leisk
    38,651
    I wouldn't want it to be public knowledge, but we're using our block heater year 'round. Oh woops.
  17. Mendel Leisk
    38,651
    A block heater never get the engine to operating temperature, that's not it's intent. It raises temps about 30 degrees centigrade. And yeah, no way the car's batteries could handle this, and it's sawing off the branch you're sitting on.
    Simtronic likes this.
