Drastic reduction in MPG 2008 - at 40,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by asmull, Jul 27, 2010.
  1. asmull
    asmull Junior Member
    Northern California
    Hello from Anita. I am a Newbie on this site.
    I have just read a discussion, comments and recommendations (THANKS!) on this site about reductions of MPG. I am at this moment sitting in the waiting room of my local Toyota dealer after being told there is nothing wrong with my my 2008 Prius; I have had a sudden reduction of my MPG from 44.5 to 33.5 after having the 12V battery jumped when I left an interior light on. (a coincidence, I don't know)
    I have done the suggestions here myself and the dealer also did them along with some other tests. When I pressed the "Vehicle Signal Check" while in Maintenance mode, I got a reading of 11.6 volts (the note here says it should be 12.4-12.8) The dealer said that when they did this it went up while sitting in this mode. They also did some test where there was a reading of 450 (I forgot what reading this is) and that meant that the battery was fine.
    They ran the car through a bunch of other tests and pronounced to me that "We cannot find anything wrong". My service rep said that he and the head tec were putting a "claim ticket" in to Toyota with the complaint so that if there enough complaints like this then maybe there will be some investigation. (my interpretation, not a quote)
    I am on the verge of tears. I have had my Prius for 2 1/2 years and feel very disappointed. Any more help or feedback is greatly appreciated.
    Anita
  2. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    As I'm sure you will hear from others, the 12v battery is the most common source of otherwise unexplained low MPG. If you have followed the testing procedures and the battery failed, I would have it replaced regardless of what the dealer said.
    Hope you regain the faith in your Prius!
  3. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Anita,
    I'm afraid that the folks at your service department don't know their
    a$$ from a hole in the ground. These are classic symptoms of a bad
    12V battery:
    FWIW, failling/failed 12V batteries are probably the most common
    problem with the Prius.
    The 12V batter has a service life of ~4 years... if all goes well.
    Fully discharging the puny 12V battery even once starts a rapid
    downhill slide. To compensate for the dying battery, the HSD has to
    divert more and more engine power to the High Voltage Battery which
    in turn is converted to 12 power for all the little things that are needed
    or used when you drive; computers and control units, lights, radio,
    windows, etc.
    I'll bet money that your 12V battery is very weak and if you don't do
    something quickly, it may leave you stranded soon. A new battery at
    the dealer should cost about $200 installed. There are other options
    available on the "Net, but by the symptoms you've given, you could be
    in a no-start situation tomorrow, vice the 4-5 days on delivery from
    these folks:
    12 Volt (12v) Toyota Prius Auxilary Battery for Prius with installation kit
    Something to read:
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
    Keep your chin up girl, this is most likely a very simple problem to fix. :cheer2:
    [ame="http://www.youtube.com/watch?v=ZBR2G-iI3-I"]YouTube- I Will Survive[/ame]
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Anita, please relax & suck down some of the free tea in the waiting room. 1. Trickle charge your existing 12v battery & keep an eye on it. If it won't hold a charge then you'll have to buy a new 12v sooner rather than later.
    2. If it holds a reasonable charge then you're looking at buying a 12v battery later.
    You can cut through some of the BS in the shop by either telling them to swap out the battery (skip the diagnosis) or buy the battery & DIY. You may find that quoting your voltages demonstrates that you have an idea of what's going on which will reduce the BS.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Sounds like maybe your 12V battery is bad. :madgrin:
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    2 1/2 years is short. Maybe the car don't get driven often?
    Another thing to check is the battery connections in the trunk. Sometimes the problem is corrosion or loose connections. Good luck! :)
  7. asmull
    Northern California
    Hello all!
    Thank you so much for all of your responses. I am very appreciative!
    Getting new 12V battery today. I will report back...
  8. JimN
    7,028
    1,116
    South Jersey
    Check the voltages before leaving the lot. Often enough, fully charged batteries are not installed. Your new battery will have a 1 year unlimited mileage warranty.
  9. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    If nobody has mentioned it I think your 12V battery may be bad....
  10. asmull
    Northern California
    Yes, a lot of folks have said this. I have replaced the battery a couple of days ago and am going to report back soon! :mod:
  11. asmull
    Northern California
    The coffee is actually quite good there!
