Drcc from 0mph
Discussion in 'Gen 4 Prius Main Forum' started by ensoruk, May 22, 2019.
  1. ensoruk
    ensoruk Junior Member
    43
    22
    UK
    2019 Prius
    Excel
    Hi
    Is it possible to start the DRCC into "waiting" mode whilst at 0mph? I know it's possible when you have a vehicle in front of you, but what about when there is nothing in front of you? Mine does not seen to allow it....
    Phil
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I think the minimum speed at which the DRCC can be started is 28mph.
  3. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    I seem to be able to engage DRCC even when standing still at 0MPH... providing there's a car in front of me
    Phil
    Tyfly likes this.
  4. Tideland Prius
    16,615
    You can't do it without a car in front of you. (It's the as coming to a stop - you need a car in front of you, otherwise, it'll cruise through the intersection).
  5. ensoruk
    43
    22
    UK
    2019 Prius
    Excel
    Ah, thats a shame.... it would be useful, never mind
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Simple answer - no.
  7. alanclarkeau
    7,045
    7,593
    I don't think it would be useful (as @Tideland Prius said).
    If you're stopped, and actually did engage DRCC set at 110km/hr:
    1) it wouldn't happen - because you'd either not be in D (ie P), or you'd have your foot on the BRAKE (which only works for setting DRCC if there's a car in front); or
    2) if it did - it would immediately accelerate to 110 - Uggggh.
    Even if there is a car in front, it will only engage at the minimum speed - ie 45km/hr, you have to be moving to wind it up to 110.
    WITH the new version DRCC on latest RAV4, the manual indicates that it will set at a lower speed, but not stationary:
    "Accelerate or decelerate, with accelerator pedal operation, to the desired vehicle speed (at or above approximately 20 mph [30 km/h]) and press the “-SET” switch to set the speed."
  8. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    You can hold the up stick up until maximum (I believe 108 MPH), but as long as the guy is doing zero in front of you it will stay at waiting. I sometimes turn mine on when behind someone so I dont have to hold the brake. EDIT: I misread your original question, yes, you have to have something in front of you, otherwise it will not wait to engage.
    alanclarkeau and Tyfly like this.
