Dreaded triangle, then restarts after 5 attempts
Discussion in 'Generation 1 Prius Discussion' started by IaintZWalrus, May 3, 2012.
  1. IaintZWalrus
    IaintZWalrus New Member
    Fix It Again Tony
    2002 Prius
    Hi folks,
    I bought a 2002 abt a year ago, and every 1000 miles I get the red triangle and the gas engine refuses to start. Initially it starts, then shuts down after a few seconds. Weird thing is, after the 5th or 6th attempt, the car starts normally and off I go. When I turn the key to "on" the check light goes on. This has never happened while I drive, only after the car has been driven and parked.
    Appreciate your comments, thanks.
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    might have been better if you had posted in the correct forum section... can't say I have seen the issue you're describing..
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    It is a very common problem in a 2001-2003. The throttle plate is sticking shut and needs to be cleaned.
    2 people like this.
  4. BGGirl
    BGGirl Member
    480
    84
    Kentucky
  5. IaintZWalrus
    Fix It Again Tony
    2002 Prius
    Thanks a lot friends, I forgot to mention two small details:
    1) initiallly the engine spurts then dies, after the third attempt it starts but the triangle and the -hybrid system- warning lights remain, I have to turn it off/on a few more times for the car to get back to normal.
    2) When the engine starts after the second attempt a creepy grating noise is heard , seemingly from the rear of the car, then it goes away.
    Any clues?
  6. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Engine "spurting" -- the engine is not actually running. MG1 is turning it over but there is no air to mix with the gas, so it will not fire. This will set P3191 and/or P030x codes. If you have a few successful restarts, then the codes will clear. The "grating" noise...that's interesting. It could be related to having unburned fuel in the exhaust due to the misfiring.
