Drive 400 miles one way in '06 Prius with 175k miles or 2010 Honda Accord with 185k?
Discussion in 'Gen 2 Prius Main Forum' started by dslomer64, Jul 4, 2017.
  1. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Prius check engine light has been on and off, mostly off, for years. Replacing ignition coils turned it off for awhile.
    Next code: ignition coil. I said they've been replaced. So Toyota suggested another near-$1000 to replace (if I recall) injectors, saying they can also throw same code. I said car's running fine, no misfiring. Light went off.
    Back on, lots of codes had been stored, probably cascade effect, said service manager. Not sure where it began or what to fix, so let it go, he suggested, until we can get better handle on codes. That was last year. Light mostly off since then.
    Red "!" came on last week at power on, along with Check Engine. Wife showed me. I looked under hood at levels I could see, and oil. Nothing obvious wrong.
    Powered off and back on: no "!". This exact thing happened once before last year, both days 90°+. She was seated, I couldn't see message, and she didn't look before it went away. Usually, out of six times "!" has appeared, it's gone off immediately. The times I could look fast enough, OIL has been indicated as problem. Never low. Nothing else ever indicated.
    I could go to Toyota to see what code is stored, but Check Engine light is almost always off before I can go. Right now it's on. They're closed.
    Prius plugs and serpentine belt have been replaced around 120k. Not sure about timing belt/chain or PCV valve; doubt it. Original water pump has residue on body, but never added coolant.
    I'd say both cars have been well-maintained except nobody knows what to fix on the Prius, if anything. Both cars seem to run fine.
    Under these conditions, would YOU drive it 400 miles one way on Saturday, back in a week, with little driving in between? Or take my son-in-law's Accord? Or either or neither (I.e., rent for $260)?
    Gen 2 (2006) and Gen 4 (2017)
  2. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    I'd take the 2017 Gen4.
    'LectroFuel, RCO and dslomer64 like this.
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The idiot light would have stored codes. If you won't/can't get the dealer to read and explain the codes then you will have to learn how to diagnose the car. Look for mini vci. I would also get a ScanGauge for the instrumentation (and it will read (most) of the DTC). I would want to see coolant and inverter temps (not sure if you can see engine temp at the same time).
    Something is leaking coolant. There are two pumps, one to circulate coolant for the engine and one for the inverter.
    On the dipstick is the oil closer to clear than black and is the level close to the top?
    I would not want to take a 400 mile trip through the emptiness of Ohio or western PA with an idiot light as that is inviting disaster. I suspect that running the car for 8 hours in 90F temps will put enough stress on whatever is failing to cause a failure. Getting stranded on a flat stretch of pavement 45 miles from the next rest stop is one thing. Having a failure going down a mountain is another.
    Post the codes you do have so the experts here can point you in the right direction.
    dslomer64 likes this.
  4. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    '06 Prius is not making the trip. Thank you for making that a no-brainer. Though I couldn't express it, the 400-mile non-stop trip leading to failure is what I more of less thought made it ineligible. Honestly, I had no intention of letting someone else drive it, but I wanted backup. I'm also not so keen on the Accord. (Daughter's small family trip; their Accord.)
    As I recall, there was a recall to replace the internal pump and that has been done long ago.
    There's no wet area near the external pump. As I think Toyota told me, a very slow leak through a weep hole accounts for the dry residue. I've NEVER added coolant.
    "On the dipstick is the oil closer to clear than black and is the level close to the top?"
    Yes, yes. Oil change 1000 miles ago. Oil on dipstick looks like new oil.
    I'm assuming you think coolant is being sucked into the engine, but coolant level never changes.
  5. dolj
    dolj Senior Member
    7,501
    3,768
    Wellington, New Zealand
    Not sure if I read and understood your OP, but are you saying the master warning light (red triangle with exclamation point) flashes briefly at start up? If so, this is the only indicator that the 12 V battery is in imminent danger of failure. Have you thoroughly checked the 12 V battery? Also, have you checked for turbulence in the inverter coolant tank? Best done with the car in IG-ON (two presses of the power switch with foot OFF the brake) or if you check it with the car in READY, wait until the ICE stops (takes about 50 seconds with the AC off).
  6. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Light was steady ON at startup three times EVER (other two were months, maybe years ago), never flashing briefly, and was NOT on after powering off and on , so I assume that doesn't point at battery. Toyota found it healthy last month. Supposedly.
    I assume I WANT to see coolant FLOW that is NOT SMOOTH but is irregular and maybe bubbly inside the sort-of-clear coolant reservoir sitting right up top inside the engine compartment and containing pink fluid (coolant) between max and min marks. (Obviously I've never been down this road and prior to Googling didn't know terminology.) I'll remove the cap and peer into the reservoir if I don't clearly see turbulence through the plastic body.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Are you looking for "permission" to drive a 11 year old Prius, throwing codes on a 800 mile round trip?
    I can't give it to you.
    I think I'd rent a vehicle, take no risk with mine or a relatives and call it even.
    Do you just not want to take a long road trip in you 2017?
  8. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I'm not taking the trip. Neither is the '06. Rental not out of question. Just inquiring.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    It doesn't seem like anything is wrong with the Accord, so take the Accord. It's better to drive a car with no dash lights than with them.
  10. Rph74
    Rph74 Active Member
    290
    234
    Springfield,MO
    I take my 2006 Prius on 500 mile one way trips all the time (just did it yesterday in fact) .....but even I wouldn't drive with your 2006 as it is running now.
  11. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Yes. Turbulence both ways.
  12. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    P.S. She rented a car, didn't chance taking Prius per advice here, but there have been no problems since. Thanks for clearing my head.
    Rph74 likes this.
