Drive battery discharges over 7 days of no use
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lou Fezio, Jul 29, 2017.
  1. Lou Fezio
    Lou Fezio Junior Member
    29
    I have an 05 Prius with 75K miles and for the last 18 months or so am developing a problem where the traction battery discharges when I don't use the car. I live at the bottom of a hill that is just long enough to run the battery up to the full 8 bars on the charge indicator when I park the car. This morning after sitting for 6 days I only had 2 bars of charge. A year ago it took 2-3 weeks for this level of discharge. The battery will come back up to charge when I run the car so it's not an issue with charging. It acts like there could be a small drain on the battery or perhaps the battery is failing?
    Can anyone offer advise on how to troubleshoot this or offer insight on how to proceed?
    51,155
    more like ly just due to age. you would need tech stream to read the battery under load. another option is grid charging with a pro long charger from the prius chat shoppe.
    jerrymildred likes this.
  3. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Your HV battery is showing its age; prepare for the inevitable.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    edthefox5 and Raytheeagle like this.
  5. Lou Fezio
    29
    Yeah, my sense is the battery is failing.
    A couple things: Are reconditioned batteries worthwhile? They are certainly cheaper but if I intend to keep the car for another 5 years or so are they worth it? Also, I'm reading that the battery is cooled by air from the cabin and this system can get loaded up. I often have my big, hairy dogs in the car and there is often hair swirling around the cabin. I'm wondering if dog hair could be impeding the airflow. to the battery? Is there an easy way to check/clean? If I'm going to invest in something like the Prolong charger I want to be sure that I don't have this issue.
    Is a Toyota dealer the only source of new batteries?
    Thanks for all the advice.
  6. fotomoto
    5,629
    3,802
    So. Texas
    Yes, yes, yes PLEASE clean the battery fan ASAP!!!!
    5 years? Only real option is to get a new Toyota battery. $2500-4,000
  7. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Here is a video how to for cleaning the fan.
    2006 Gen 2
    2014 Gen 3 v wagon
    #7 hchu1, Jul 29, 2017
    Raytheeagle and bisco like this.
  8. bisco
    51,155
    would you diy the battery swap?
  9. Lou Fezio
    29
    Ok, did the fan cleaning. It was dirty but not blacked at all. But now I get the red triangle when I try to run the car. Electrically all I disconnected was the traction battery and the fan. The display just says "problem". Do I need to disconnect the 12V battery to reset the system?
  10. bisco
    51,155
  11. bisco
    51,155
    check the orange safety switch. you have to slide it after locking it down. there's a youtube video...
    kenoarto and Raytheeagle like this.
  12. Lou Fezio
    29
    I had to both finish locking the orange safety switch then reset the 12V system to clear the problem.
    Thanks, guys.
    kenoarto and bisco like this.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Fussy little things aren't they.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Why did you pull the hybrid battery orange interlock?
  15. 05PreeUs
    1,097
    564
    MSP
    Better safe than sorry???
  16. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    Yeah you don't wanna mess with that stuff. Source: I just finished my hybrid training at the Toyota training center.
    iPhone ?
  17. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Many reports of successes and failures with used/refurbished batteries. It's a crapshoot and they range in price from $500-$2000. Some guys will come to your house! Brand new Toyota batteries can be purchased Toyota dealers for as low as $2000. You can choose to DIY, find an independent mechanic, or have a dealership do the work. Alas, even with a genuine, new Toyota battery, the best warranty is only 3 years.
  18. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    We charge about around $400 to swap. I wouldn't risk DIY. I mean in training, they tell you if you see someone being electrocuted by a hybrid battery, that we aren't supposed to do anything to help, because they are already gone.
    iPhone ?
    bisco and kenoarto like this.
  19. kenoarto
    398
    Chicago, IL
    What are the prices of your batteries?
    What is your warranty?
  20. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I'm not exactly sure about the warranty. I can check tomorrow. I don't think it's that great though.
    iPhone ?
