Drive battery
Discussion in 'Gen 3 Prius Technical Discussion' started by GTO, Jun 28, 2017.
  1. GTO
    GTO New Member
    Arizona
    Can't find an answer to my concern. How do you how the drive battery is having issues? I just bought 2014 Prius III with 59K and have noticed that when I get into the car the drive battery only shows 2 bars but charges up whiles driving. When I park and return in a couple hours the battery is back to 2 bars again. Is this normal?
    49,492
    it can be normal, especially in a very warm climate.
  3. Tideland Prius
    16,155
    You mean you park the car with more than 2 bars and it drops to 2 bars when you return? It *can* signify a problem but it depends on where you started. If it was 4, 5, 6 bars, it's a problem. If it's 3 bars to 2, it could just be a rounding error or a recalibration upon start up.
  4. Former Member 68813
    3,524
    981
    US
    Maybe car is not turned off?
  5. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    In high heat such as AZ (the OP) or Texas, dropping more than a bar after sitting happens even with a new car/battery.
    Tideland Prius likes this.
  6. Tideland Prius
    16,155
    Good to know.
  7. fotomoto
    5,602
    3,779
    So. Texas
    It happens to me with LiOn chemistry as well.
  8. Tideland Prius
    16,155
    I find the Li-Ion in the Gen 4 is more eager to cycle through the range of SOC. It'll use it more readily and it will charge it up more easily than the NiMH in the Gen 2 or 3.
