Drive-by-wire question
Discussion in 'Generation 1 Prius Discussion' started by hybridtwins, Aug 21, 2009.
  1. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Throttle-by-wire question
    IIRC I saw something in this forum to the effect that the gen1 Prius uses a mechanical contact wiper along a resistor as means of throttle control.
    If this is correct, it seems a bit retro even for a 2002 model; an optical or magnetic (Hall effect?) solution would've been better.
    Has this design been changed in the newer Prius generations?
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    Gen2 Prius went to a set of Hall effect sensors. I would assume the Gen3 uses a similar design.
