Drive Modes
Discussion in 'Prime Main Forum (2017-2022)' started by MikeDee, Dec 6, 2016.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    When should I use EV Auto mode? EV mode? CHG mode (what is that)?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Basic rule: slower speeds/short drives=EV, fast speeds/long drives=hybrid. There will be exceptions.
    CHG mode will use the gas engine to charge the battery.
    #2 fotomoto, Dec 6, 2016
  3. MikeDee
    1,581
    597
    Why would I ever want to use CHG mode? It would seem to me that running in HV mode would be more efficient.
  4. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I will definitely use it on a long trip !
    I don't know if it's true,but charge mode apparently is capable of charging the battery up to 80% in just about an half hour while getting not too bad fuel economy while doing it ! (maybe 42-44 mpg ?)
    So why not have slightly worse fuel economy for about an half hour but afterwards enjoying emissions free driving in town ?
    Somebody here tried it out for thirteen minutes and was averaging astonishing 48 mpg !
    I think it's great Toyota thought of it !
    You can use it but you don't have to,so the choice is yours !
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    There's already extensive discussion on this.
    My opinion, not owning one yet, but having used it on two test drives:
    I'll use it on long trips where I know I won't have the ability to charge at the stops and where I know I'll be doing short trips at those stops. This will save warmup cycles because I won't have to start the engine to make those short trips.
    I'll use it before big high-mountain climbs to assure I'll have plenty of electric power all the way up the hill.
  6. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    Hmm, if it's anything like the Chevy Volt's various modes, I can try to chime in. Feel free to correct me if I'm wrong.
    EV mode is strict EV driving so long as the battery has a charge. Then when it runs out, it'll switch to hybrid mode, aka a regular Prius.
    EV auto mode sounds like the Prius will use whichever power it determines is most efficient for what you're doing at the time. So on the freeway I'd imagine it'll run in hybrid mode, then when you jump off and do city driving, or get stuck in bumper to bumper traffic, it'll switch to EV mode.
    CHG mode, if it's anything like the Volt's "mountain" mode, will force the gas engine to run to recharge the battery up to a certain amount, say 25-40% of the charge.
    For the Volt, this gives the electric motor a buffer so that it can run with the gas engine to help you go up steep mountain passes at higher speeds, like say 75 mph. The gas engine, at least in the 2011-15 Volts, isn't powerful enough to go up steep inclines on its own, and if there's no battery charge, it'll give you a "reduced propulsion" message, and run slower until the gas engine has been given a few minutes to run to charge up the battery.
    Note that in the Volt, by design you can never fully charge up the battery on gas alone. GM's engineers made it so you have to plug it in to get a full battery.
    I'm guessing the Prime will also behave in a similar way, in that the gas engine will never fully charge the battery on its own. Partly because burning gas is the least efficient way to gain back electric miles, but also because that would defeat the purpose of plugging it in in the first place.
  7. civicdriver06
    797
    324
    Germany
    It will charge the battery up to 80 % !
  8. Lee Jay
    5,850
    4,036
    Once the battery is close to depleted, it may start the ICE at high throttle positions.
    80% max on Prime.
    We think, but aren't sure, that a long decent will do it as well.
  9. MikeDee
    1,581
    597
    EV Auto puzzles me too. Wouldn't you think that if you mashed the accelerator pedal, the computer would recruit power from the battery and engine anyway so you get maximum power output? So why the need for EV Auto?
  10. Lee Jay
    5,850
    4,036
    Ev Auto is about efficiency, not power output.
    Most people are reporting that, in practice, it's mostly Ev.
  11. MikeDee
    1,581
    597
    That's not what the manual says, page 80:
    "Switching to EV auto mode make powerful driving possible by using both the gasoline engine and electric motor in a driving condition that requires large driving force, such as when passing a vehicle on a highway or driving on a steep slope."
    Lee Jay likes this.
  12. Lee Jay
    5,850
    4,036
    Okay, that's not what the engineer said.
    Regardless, it will do that at the end of charge anyway (I personally experienced it starting the ICE in Ev mode when I floored the throttle) and that's because that's when the battery no longer has the capability to run the motors in dual-motor mode at full power.
  13. civicdriver06
    797
    324
    Germany
    How does passing power compare to the liftback ?
    Is it slightly worse due to the extra weight or is it hopefully even better ?
  14. Lee Jay
    5,850
    4,036
    I personally couldn't tell the difference, but I didn't drive them on the same day. Months apart, in fact.
  15. Trollbait
    12,689
    EV auto is how the PiP and Energi's work in EV mode. Many people didn't like this; they wanted pure EV operation while in EV mode.
    With dual motor operation the Prime has more power available than the PiP did in EV mode, so pure EV became possible for it. The EV auto is there for when a trip in beyond EV range, and the driver doesn't want to manually determine when to use EV or hybrid mode.
  16. Tideland Prius
    16,621
    No. Some people like the ability to stay in full EV so EV Mode will lock out the engine. In addition, some places (not in North America) allow only EVs inside downtown or the CBD so having the ability to lock out the engine is helpful (and combined with the CHG function to charge up the battery so that you can enter downtown in EV mode).
    Basically EV Auto is for efficiency. It's usually more efficient to use the engine under heavy load (like quick acceleration or going up the mountain).
    If you know your entire trip can be done in electric and you can charge at the end of your trip, stay in EV mode.
    If you're travelling a longer distance, you can switch to HV or EV Auto to use a blend of the two power sources.
  17. Lee Jay
    5,850
    4,036
    As I said above, I got the engine to start while in Ev mode (not Ev auto) at a high throttle setting and a low state of charge.
    Tideland Prius likes this.
  18. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    He was averaging 48 mpg for the whole trip while in HV mode (i.e. deducting the two EV sessions), not only for the period of using charge mode.
    We still lack info regarding performance and efficiency of this new mode.
    #18 giora, Dec 6, 2016
    AshPrime likes this.
  19. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    We had one prospective buyer who had no place to plug it in. HE could use "CHG" mode to charge it up so he could then sneak around in EV mode. ;)
  20. MikeDee
    1,581
    597
    Sounds like I should be in EV Auto for most of my driving. I only use the car several times a week and around > 100 mostly highway miles per drive. Some are 35 miles. I drive an old pickup around town because I don't want my new car to get dinged up in a parking lot. Power costs are $.24/kwh and gas last time I bought was $2.20/gallon, but I intend to plug in because I hate going to the gas station.
    What if I go on a long trip where I can't plug in (1000 miles)? Should I use HV mode for this?
