Drive motor 'a' position sensor circuit
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by piper18o, Nov 26, 2011.
  1. piper18o
    piper18o Junior Member
    Hutchinson
    Last night I was driving my 2005 Prius in a light rain. I had only been driving for about 5 minutes or so on the freeway. The check engine light and the big red triangle came on. It was a couple of miles before I could get off the freeway, and by the time I could get to the exit ramp, the car at times was starting to race the ice. It was beginning to feel like it was slipping the "transmission" and I felt fortunate to get it off the road. I coasted into a convenience store and parked it. My scan gauge showed me a code of POA3F. I have discovered that this is the Drive Motor 'A' position sensor circuit. What does this all mean? Is this going to be an expensive fix? After letting the car set for a while and a few phone calls later, I attempted to start and put the car in gear. It would only let me put it in neutral. Is there any chance at all that my problem could be less than major? Any help on this would be much appreciated.
  2. piper18o
    Hutchinson
    I forgot to mention that in those 2 minutes or so, the car went from 9 bar green soc to 2 bar red soc, and the ice was running.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    SoC variance is typical following a fault like that.
    Please give us your history. Are you the original owner? How many miles? When was the last time you changed your transaxle fluid? Has the car ever been in an accident? Have you reset the code, turned the car off, then turned it back on? Have you tried disconnecting the 12V negative for 5 minutes and restarting?
    Best case scenario: water has entered into a connector. Worst case scenario: need a transaxle.
    2 people like this.
  4. piper18o
    Hutchinson
    Sorry for my ignorance, and thanks so much in advance for you assistance. We just bought the car about 3 months ago and it had 67000 miles on it. When we were test driving it, the check engine light and red triangle came on. We put a scan tool on it and it threw the P0A93 code. We gave the vin number to a toyota dealer and discovered that the inverter coolant pump recall had not been done. The car also had been in a low speed fender bender accident. I believe that it had damage to the rear bumper, maybe rear fender and possibly the back hatch door area. I saw pictures of the vehicle prior to being repaired, and the damage did not appear to look too serious. It didn't seem to have a lot of damage, but it does have a salvage title. The car was drivable after the accident.
    It is my belief that the body work was done by a body shop and not a Toyota dealer. All this had been done before we found the car from the individual. Before we would buy the car, we thought we should take it to a Toyota dealer. They checked it out, and replaced the inverter pump. They couldn't find any other damage to the car. To make a long story a little shorter, we bought the car.
    We have put about five or six thousand miles on it without any problems. By the way, we had only driven this car in rain one other time. That time we drove it for about 40 miles in the rain and did not have any problems.
    We have never changed the transaxle fluid, and have no idea what has been done in the past.
    Anyway, we let the car sit for 2 windy, dry, days and then went back to see about getting it home. (It was in the town where my wife's family lives.) I got in the car, started it up, the red triangle came on and the check engine light did as well, but now it would go in reverse and back up and go in drive and move forward without any problems. I went ahead and cleared the engine code and everything seemed fine. I drove it about 60 miles home without further incident.
    I realize that I am not a very smart individual, and my shade tree mechanic knowledge will probably get me into a lot of trouble, but for the life of me, I am completely at a loss as to try and figure this one out. Any ideas? If it is just a wet connection, shouldn't there be a way to keep this from happening again?
    Thanks so much for any thoughts on this problem.
  5. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Did you get a CarFax? Possible that the car had been in an accident in front and repaired before?
    Here's what's going on. It is a signal problem. The fact that you drove 60 miles after clearing the code suggests very strongly that it is an intermittent problem due to moisture. Having it happen during rain makes it very probable that it is the connector. I have attached the wiring diagram, where I believe the connector in question is in red, M9. While you are changing out the transaxle fluid, highly recommended at this mileage and your skill level 4 qts of ATF WS only search here for more info, take a close look at this connector for damage. If there is nothing obvious, and you get this code again after a fluid change, then you probably need to have a very good hybrid tech look at it. You are in Hutchinson, KS? Maybe NorthWichita will see this and have a recommendation.
  6. piper18o
    Hutchinson
    Thanks,
    That makes a lot of sense to me. I am out of town for this week but hope to get the problem fixed by this weekend. I really appreciate this help. I really like the car, I just wish I felt a little more comfortable with all the complexities. Oh well, knowledge is power, so if I could learn a little, I wouldn't be so weak. [​IMG] Also sounds like a great idea to go ahead and change the transaxle fluid, assuming that it wasn't done at 60,000 miles.
    We didn't get a carfax, but the dealer looked up the vin number, and didn't find anything reported that we weren't aware of. It is my understanding that only things that are reported, like work done at a dealer will show up on a car fax. The body work done after the fender bender did not show up, only the accident.
