driven 128 miles on Empty
Discussion in 'Prius PHEV Plug-In Modifications' started by stefano5777, Jun 6, 2011.
  1. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    So I have driven the last few days an My last blinking pip for 128 miles and need to push it to 141 to reach the 1200 mile mark on 1 tank of gas with my 4kw enginer kit. My question is what are the ramifications of running out of fuel? Other than having to walk. Is there and detrimental damage that I can cause by pushing it? I have a Scangauge that says I have another 165 miles till empty but I do not trust it. Also I noticed my Scangauge after 1187 miles is 13 miles below what my MFD says I have driven and I have calibrated it in kph ? Any suggestions would be appreciated.
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    I wouldn't personally do this, but it is your property. What would happen is you would run out of gas, run down the hybrid battery to dangerously low levels as you continue to drive it, and cause damage not covered under warranty to the most expensive part of the car to fix.
    There's always the fuel pump and system to consider, too.
    Third option is to have it towed when you run out.
    I'm not seeing any good reason to try something like that.
  3. mikewithaprius
    656
    103
    Rhode Island
    By the way, the Scangauge distance to empty is near meaningless on any car, especially a Gen II Prius, it's just performing math like the automaton it is, not actually measuring anything in the gas tank.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Don't EVER-EVER run your Gen II Prius with the tank empty. This can cause major problems with the fuel pump and/or the fuel bladder. Owners have reported costs of over $1000 to replace these items.
  5. stefano5777
    stefano5777 Member
    380
    47
    I understand that thats why I do not know if I should push for last 13 miles. If I trusted Scangauge I would not have asked the question :)
  6. bisco
    49,691
    i ran out of gas and drove on the battery till all the lites came on and she wouldn't go no farther. triple A put in a couple gallons and i was on my way.
  7. JonnyD
    JonnyD Junior Member
    NorCAL
    I ran out of gas when I was testing my 5kW Enginer system going pass 900 miles.
    Big mistake! Gas station were readily available on my route, so I was able to refill easily.
    The problem that persist since is the fuel bladder.
    I normally fill up with 10 gallons (+/- 0.5 gal).
    But since the incident, I rarely can put 10 gals in. Several times only 6.5 - 7 gallons go in to completely fill my tank.
    Now I use iPhone App GasBuddy GasBook to track running average. IMHO it's much more accurate than one or two tank results. I had couple tank with 120+ mpg but the fad soon wear off cause everybody and their sister was passing me in local roads.
  8. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The Gen 2 Prius manual recommends the user to keep refilling the gas tank as soon as it reaches a 1/4 of a tank. There must be a good reason for this recommendation.
    EDITED 11/6/2011
  9. stefano5777
    stefano5777 Member
    380
    47
    Well I did it I did not listen and pushed it to 147 on last pip and reached 1206 miles before I refueled!!!SO my first enginer tank finished with fueling on May 6 and going till June 7 travelling 1206.4 miles and using 11.134 gallons of gas I did not track the exact amount of kw of power used but I avg roughly 2 full charges of power a day that I drove.:rockon:
  10. priushippie
    priushippie New Member
    330
    Pennsyltucky
    That is really getting some miles out of a tankful! Congrats!
  11. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    And the point of doing that was for ....?
    It's nice that your enginer kit allows you to drive it as a plug-in hybrid and all, but I still don't get the concept of pushing the tank to the last drop, possibly risking expensive repairs on your primary means of transportation, just to see some arbitrary number on your trip meter.
  12. mikewithaprius
    656
    103
    Rhode Island
    Couldn't agree with more with Nerfer. Maybe it's cause I own few things, and since the car is by far the biggest financially, I care for it quite a bit. I could never do something potentially so damaging. Without tracking kilowatt-hours the numbers also don't serve any particular purpose.
  13. stefano5777
    stefano5777 Member
    380
    47
    Jeez no need to hate so much :) arbitrary to some but not to others are those numbers.
  14. bisco
    49,691
    brilliant! bob wilson used to do these things all the time. strictly for scientific study of course.
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    People always push the limit.
  16. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    Why would anybody risk running out of gas on purpose? If you're driving on a track, OK. If you're in real traffic, you are a danger to yourself and others.
  17. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    For those that don't know, I'm going to get my 2000 Insight battery pack refurbished.
    Love that car, but the one thing I'd change is to have the software and NiMH batteries up to the resiliency of Prius IIs - they are waaaay more reliable. Toyota made sure the traction pack would be 40% charged minimum for a good reason.
    You WILL have another chance to break 1200 miles or more.
    I'd hate to see you shorten you traction battery pack's life to achieve this short term goal
  18. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    At least Bob was prepared with extra fuel waiting in the trunk. I agree it is a danger and completely not worth trying. I think the Gen3 and Gen2 prius responds to "out of fuel" scenario very differently if I remember correctly. The Gen2 allows you to drive on the battery, not sure about the Gen3.
  19. stefano5777
    stefano5777 Member
    380
    47
    Ok to clear a few things up. First I carried a 1 gallon jug of fuel with me today to complete this challenge. Second If I ran out of gas I technically still would be able to drive on enginer battery pack on top of prius. Third I only put 11.1 gallons of fuel in and have put 11.5 and 11.6 in before so after refueling I realized I could have driven another 40 or 50 miles. and to clarify another comment I own 4 cars so this is what I prefer to drive but if I broke it being an idiot I have something else to drive while it was being repaired.
  20. mrbigh
    3,686
    699
    Long Island, NY
    Hey, I think that you have to try the gas tank limit, at least once and for the records.
    If you take things with precaution, be prepared for the event and in a safely maner, it's a no brainer.
    In my 5 years of continuos daily PHEV I tryed the same thing once a year.
    Until today, I NEVER had a problem or a negative mechanical consecuence. I'm by the 75K miles on my 2004.
    Amen
