Driver’s side low not working.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Slvram, Nov 8, 2018.
Tags:
  1. Slvram
    Slvram New Member
    My left low bean went a feed days ago. Everything else has been working in the headlight. Turn signal, parking lights, etc. I thought it was the bulb and bought a new one(halogen). When I pulled the bulb it looked fine, no broken filament. I tried the new bulb and it still didn’t work.
    I tried searching for what fuse was and found a thread on here saying it was a fuse in the engine compartment. I pull the fuse and again, it didn’t looked blown to me. No broken connection on any of the three fuses. No burnt look on any of the connections. I haven’t purchased another fuse yet, but I honestly don’t think that’s it either.
    I’ve had the car for 2 years, haven’t had any electric issues other than blown license plate bulbs. Is there anything else I should check? I went to the delearship and asked the guy at the parts counter to price the fuse. It said that wasn’t the fuse for the headlight. I don’t think he knew what he was talking about. I pulled it while I had the headlights on and the passenger side did go out. He said there a control box on the headlight that could be the problem. I told him, I’ve got halogens, so I don’t think there’s a control box for the headlight. He said all Priuses have one regardless. I don’t know. Not sure what to do. Any advice would help on troubleshooting.
    Sincerely,
    Annoying Everyone With High Beams For Now :)
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    use a multimeter and check for current.
    52,801
    test the old bulb, test the fuse, test the socket
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Take a multimeter and test the physical headlight lead + and - leads inside the plastic connectors for power, if there is power/voltage then it could be the physical connection/contact where the bulb's + or - meets the socket's lead are/is corroded or coated with something causing an open circuit. Check that first before drastic measures.
