driver door controls
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by amandajc, Aug 26, 2019.
  1. amandajc
    amandajc New Member
    NC
    hi all! i have a 2014 prius with ~60k miles on it. i'm having an issue with the window/door lock controls on the driver's side door that differs slightly from other posts on this forum. the problems i'm having are:
    • only the driver's window can be controlled at all from the driver's door. the other three buttons are completely nonfunctional.
    • the auto up/down on the driver's window does not work.
    • the door lock button works ONLY when the car is off and the door is open. otherwise it doesn't work at all.
    • the window lock button does not work at all.
    • the green lights illuminating all of the window buttons on all of the doors flicker (not blinking, more like a candle flame).
    the other three doors have completely working buttons aside from the illumination lights flickering. i did not replace the 12V battery recently. any idea what may be wrong and what steps i should take?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Check the battery voltage
    51,140
    do they other 3 door lock and window buttons work?
