driver side front wheel noise
Discussion in 'Gen 2 Prius Technical Discussion' started by ssternal, Oct 13, 2010.
  1. ssternal
    ssternal New Member
    Dover Foxcroft
    I have a 05 Prius. Developed a low hum noise some time ago. It now is so loud can't hear the radio. Sounds like a heavy agressive truck tire rolling down the road. When turning the steering wheel from right to left quickly, noise level changes. Does this sound like a bad wheel bearing and if so what am I looking at for repair costs?
  2. Patrick Wong
    18,200
    6,472
    Probably a bad wheel bearing, may cost you $400 to have that replaced at the dealer.
  3. northwichita
    481
    102
    29
    Wichita KS
    Bad wheel bearings have been known to seize up when driving.... that would add to the cost.
  4. tomforst
    tomforst New Member
    32
    Without a doubt you have 1 or more bad wheel bearings. I recently had the same problem. I had a difficult time diagnosing my problem because usually you can tell a bad wheel bearing because the noise becomes louder in a turn because of the increased load on the bearing. Mine didn't do that - the noise was constant and VERY loud. I was worried that the planetary gear system was going bad. Now that the bearing was replaced, it sounds like a new Prius again. By the way, I have 150,000 miles on my 2005, and this is the third wheel bearing I have replaced. (But this is the only problem I've had with this car, so I'm not complaining.) The price my dealer charged was about $350 - money well spent because the noise was driving me crazy.
  5. mike lipke
    mike lipke New Member
    89
    MN
    Wheel bearing.
    That repair is no different on a Prius than any other FWD car.
    Get it fixed b4 it ends up on the side of the road. Any repair shop can fix it.
  6. PhazonPhobe
    PhazonPhobe His name is Sora
    221
    26
    28
    Fontana, CA
    Like everyone is saying, definitely a wheel bearing. You can probably find it cheaper than $400 if you avoid the dealer. I try to avoid the dealer.
