driver side headlight not working
Discussion in 'Gen 2 Prius Main Forum' started by robey, Mar 16, 2017.
  1. robey
    robey New Member
    las vegas
    my drivers side headlight doesn't work replaced HID bulb still doesn't work need assistance in what to look at to get it to work
  2. xliderider
    xliderider Senior Member
    7,878
    3,119
    Honolulu, HI
    There are many threads dealing with this problem. HID lights have two major components, the ballast and the bulb.
    Switch the bulbs from one side to the other. If the problem continues to be on the driver's side, then the ballast or the wiring harness/connectors are most likely the problem.
    If you can narrow down your problem to the ballast, replacements are available on ebay:
    kenoarto likes this.
