Driver side lower than passenger side.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Frederickdawg, Jun 6, 2016.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    I think I know why one side of the vehicle sits lower than the other. Wondering if the RHD versions are lower on the same side also?
    LG-H901 ?
    epoch_time likes this.
  2. frunkit
    frunkit New Member
    Central PA
    Why? Driver had too many donuts?
    Coast Cruiser and Mendel Leisk like this.
  3. bwilson4web
    15,523
    How measured and by how much?
  4. Frederickdawg
    596
    335
    About half an inch.
    My theory about the driver side sitting lower is this.. Remember the vehicle was primarily designed for the RHD market, thus the left side is lower or right side higher, so that when the driver gets behind the wheel on the right hand side the vehicle is then well balanced.
    This suspension area was not modified in my opinion for the LHD market. I have seen this on other manufacturers also, in particularity some RHD BMW models sitting lower on the right hand side. As they were designed for the LHD market for example.
    LG-H901 ?
    #4 Frederickdawg, Jun 7, 2016
  5. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Seems odd...corner weighting should have the drivers corner higher than the unloaded corner.
    Fill the gas tank and re-measure.
    Coil springs would be where I'd investigate to make sure all is in order.
    Faulty shocks doubtful.
    Suspension caster chamber toe doubtful.
    Body panel alignment/ attaching points possible.
    Flat tire?
    Always best to measure at frame points and not from fender lip point.
    Good luck...please post the answer you uncover.
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Easy. Just add an extra pound of air to the tires on the lower side! :)
    (F-dawg, you still got Goldfish swimming around in your headlights??? :LOL: :ROFLMAO: )Yep. That's pretty much me. ;)
    My new Prius is definitely listing to the Port side...
  7. Frederickdawg
    596
    335
    Goldfish? More like cat fish. Lol
    Never had water in there. Just remnants of water. Example, dried droplets . As did previous ride from new. Normal.
    Only outstanding issue is the sunroof windnoise after vent closure. Can take care of that myself once I have the time.
    Guess who noticed the driver side sitting lower than passenger. ? Just my loving spouse that wouldn't normally notice anything. With anything, I mean anything. LOL
    LG-H901 ?
    Coast Cruiser likes this.
