driver's door keyless entry does not work
Discussion in 'Gen 3 Prius Technical Discussion' started by ep1, Dec 20, 2024.
  1. ep1
    ep1 Junior Member
    so cal
    My daughter's 2013 Prius 3's driver door's keyless entry doesn't work.
    The keyfob button press will unlock and lock the driver's door.
    The keyfobs work on the tail gate and front passenger door.
    --> the keyfobs are ok.
    I listened for the 134.2kHz beacon from the doors.
    The passenger door handle area is emitting the beacon. The tail gate and the driver's door beacon are not present. what assemble is the beacon's circuitry contained in ? Is it the large wiring harness that surrounds the door handle inside the door or is itembedded in the door handle ?
    I'd like to fix it. A part number or picture of the most likely suspect assembly would be greatly appreciated.
    P
  2. Tombukt2
    Tombukt2 Senior Member
    12,014
    2,123
    Durham NC
    Sorry in door handle me thinks . And it's connected to black box on door that has that mghz range stamped on it.
  3. ep1
    ep1 Junior Member
    so cal
    Tom
    Thanks, do you happen to know the part number ?
    P
  4. Tombukt2
    12,014
    2,123
    Durham NC
    I'll have pictures in the morning and I'll send them to where you told me to or send me an email to my name here at Gmail and I'll send you the pics as soon as the sun comes up I have both parts I'm sitting out for you to look at
  5. ep1
    ep1 Junior Member
    so cal
    Tom;
    Thanks, please just post them to this thread if possible ?
    P
