Driver's door noise opening
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Coffee Bean, Feb 9, 2019.
  1. Coffee Bean
    Coffee Bean New Member
    Washington
    2016 Prius c
    Driver's door makes crackling noise when opening. No obstructions or loose parts I can see.
  2. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Without hearing that "crackling" noise for myself... It's going to be hard to say what it is
    My first thought is the weather strip sticking to your door. It's about the only thing I could think of that would make a "crackling" noise (or anything like it). There are several things you can do to keep that weather strip from sticking to your door. Some spray a rag with WD40 and wipe it on the weather strip, others use chapstick. Techs at my old dealership had a jar of Vaseline.
    I'd try that first and when you do, apply it lightly.
  3. Mendel Leisk
    38,735
    Hinges are lubed? Try silicone on the weatherstripping.
