Drivers Power window autoup THEN half down
Discussion in 'Gen 2 Prius Technical Discussion' started by bqs, Mar 21, 2011.
  1. bqs
    bqs New Member
    I recently had to change my remote battery which was causing the car not to start. Now when I use the auto-up feature on the drivers window it does go all the way up BUT then also goes down halfway. Any ideas?
  2. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    just manually run it up and down a couple of times to reset it. This usually means a loss of 12v power happened.
    JeffD
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The procedure is in your Owner's Manual.
  4. Patrick Wong
    18,200
    6,493
    If the window goes down without your pressing the driver's window button in that direction, then I would say that you should have the window checked out. Perhaps the mechanism is binding.
