Drivers Side Dive Seal Leaking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by glen hansen, Oct 27, 2012.
  1. glen hansen
    glen hansen New Member
    Installed new wheel bearings on driver side. Drive axle threads were bad so changed drive with new axle from Auto Zone. When changing axle noToyota dealers had a new seal. After installing new drive axle seal started to leak.
    Then I took it to Toyota for a new seal. Still leaking . Toyota installed another new seal and still leaking.
    Please help. !!!!!!!!!!!!!!!!!!!!!!!!
  2. Patrick Wong
    18,210
    6,514
    Maybe the axleshaft has an incorrect diameter which is causing the seal to leak?
