Drivers side fender liner fell off on Interstate
Discussion in 'Gen 2 Prius Main Forum' started by Jim Porta, May 9, 2017.
  1. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    Heard a scraping noise then bumping and saw something disappear behind me. The Prius continued running fine.
    Checked at home and found complete fender liner gone! I haven't done anything to the liner before that.
    One electronic piece was dangling loose so I wire tied to a bracket temporarily.
    Don't know what all I need to fix this ( fender liner, bolts, clips,etc) or why it happened. Has anyone else had problems in this area?
  2. JGC61
    JGC61 Active Member
    214
    101
    Long Island
    Same thing happened to my 2010.
  3. Jim Porta
    86
    17
    Louisville, KY
    Where did you get it fixed? Must it be a Toyota repair?
  4. Mendel Leisk
    38,726
    The main pieces might be items 1 through 3 here:
    INNER STRUCTURE for 2006 Toyota Prius | Toyota Parts
    Not sure about the fasteners. Is the other side intact? That'd be a gold mine of information. I would just jack up the whole front end, set it on jack stands, remove both wheels, use the other side for reference. Take off fasteners and pieces on the good side. Verify what's what.
    To get a dealership to repair this could run up quite a bill I'd speculate.
    Too: these things don't just "fall off", it takes lots of neglect.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,915
    Columbia, SC
    Same exact thing happened to one of my 2005s. Such a wonderful surprise while driving on freeway.
  6. dolj
    dolj Senior Member
    7,652
    3,866
    Wellington, New Zealand
