Drivers side LED brake light dim
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cezarcaz, Jun 7, 2013.
  1. Cezarcaz
    Cezarcaz Member
    102
    49
    Chino
    I drive an 05 Prius the drives side LED part of the light is dim. I went to the dealer and they told me I had to buy the hole light assembly. Is this true? if not Does anyone have or know where I can buy a used assembly? Thanks in advance for your help.
    iPhone ? 2
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes, its true. The whole assembly will need to be replaced.
    U can try eBay but be careful......it might have the same issue if its used.
  3. Cezarcaz
    Cezarcaz Member
    102
    49
    Chino
    Thx
    iPhone ? 2
  4. Patrick Wong
    18,200
    6,500
    It is true that if the LED light assembly has failed, then you would need to replace the entire taillight assembly.
    However before you do that I suggest you check the wiring harness connections to make sure they are secure and that the ground connection to the body is tight. You'd probably be irritated if you replace the taillight assembly and find the same issue with the replacement unit. If you have a digital multimeter you may want to verify voltage to the brake light LEDs and compare to the other taillight, while you have a helper depress the brake pedal.
    Rokeby likes this.
  5. SubPrius
    SubPrius Junior Member
    31
    Patrick,
    Where is the taillight assbly ground connection located?
    Can it be tightened without disassembling too much?
    Thanks,
  6. Patrick Wong
    18,200
    6,500
    I haven't needed to find this myself but believe that if you remove the plastic trim surrounding the hatch floor opening around where the lock is located, you will find some wires bolted to the body.
  7. Karkus
    Karkus Junior Member
    38
    Boulder, CO
    2019 Prius Prime
